Coolant Temperature Sensor G2: Audi A3 TDI AGR Location
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post11-10-2004, 12:54    Subject: Coolant Temperature Sensor G2: Audi A3 TDI AGR Location Quote
Yesterday, I read the error codes from my friend's car.
The reason was that the engine temperature gauge showed 60 degrees.
It dropped to its lowest value after reaching 90 degrees.
1 error found:
Engine coolant temperature sensor G2 is defective.
Short circuit to ground.
I don't have the error code handy right now.
According to the measurement block, the engine temperature is being measured correctly.
The question is, where is this temperature sensor G2?
How can I possibly fix it?
Translated on 02-11-2026, 4:40.
Post11-10-2004, 13:06    Subject: Coolant Temperature Sensor G2: Audi A3 TDI AGR Location Quote
Isn't that the double temperature sensor located at the "cylinder head, water outlet to radiator" connection?
One for the MSTG and one for "in the speedometer".
</speculation>
Translated on 02-11-2026, 4:41.
Tagessuppe
Post11-10-2004, 16:16    Subject: Coolant Temperature Sensor G2: Audi A3 TDI AGR Location Quote
Do you have any idea where he is?
Severin.
Post11-10-2004, 17:32    Subject: Coolant Temperature Sensor G2: Audi A3 TDI AGR Location Quote
Tagessuppe wrote:
Do you have any idea where he is located?
Hmm... Martin wrote the following:
dieselmartin wrote:
...to the "cylinder head, water to radiator outlet"...
Okay: Check the upper water hose between the engine and the radiator. Follow it in the direction of the engine and look for a four-pin connector on the engine-side connection icon_wink.gif.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 02-11-2026, 4:42.
No new posts Reverse Light Wiring: Location & How-To Transmission, Chassis, Body & Interior
No new posts Pressure Relief Valve V71: Where to Buy? Transmission, Chassis, Body & Interior
No new posts Relay 109: Location for AFN vehicles Diesel Engine Technology
No new posts Ignition Wiring Golf 3: Find It Here! Transmission, Chassis, Body & Interior
