VAG-Com 409-0 Adapter: Troubleshooting & Problems
WarLord
Post23-10-2004, 13:25    Subject: VAG-Com 409-0 Adapter: Troubleshooting & Problems Quote
I'm having problems with VAG-Com 409-0 on an HP Omnibook 6100 (Pentium III Mobile with 1 GHz), which has Windows XP installed. Rainer's adapter is not being recognized, and therefore I can't access the control units. When I try to select the control units, I get an error code 2. If I switch the switch, I get error code 1.
What could it be? The adapter worked without any problems with Windows 2000 and version 311-2.
Best regards, WarLord.
Translated on 06-09-2026, 2:50.
Post23-10-2004, 23:28    Subject: VAG-Com 409-0 Adapter: Troubleshooting & Problems Quote
Then your kit is probably too old... icon_confused.gif In July, there was a hardware change, but unfortunately, it doesn't work with the new VAG-COM versions.
Translated on 06-09-2026, 2:51.
WarLord
Post24-10-2004, 10:54    Subject: VAG-Com 409-0 Adapter: Troubleshooting & Problems Quote
'Is this for the July release? Then my kit is really outdated (February/March of this year). Is it possible to adapt it somehow?'
Translated on 06-09-2026, 2:52.
Post24-10-2004, 18:10    Subject: VAG-Com 409-0 Adapter: Troubleshooting & Problems Quote
An "upgrade kit" was once planned, but unfortunately, it proved to be unsuitable. So, it doesn't look promising.
Man muß recht viel ändern. SI'll send you a private message.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts @Rainer: Is the USB dongle adapter no longer available in... On-Board Diagnostics (OBD)
No new posts Problems during initial setup of kit B1 On-Board Diagnostics (OBD)
No new posts Problems with VAG COM adapter Diesel Engine Technology
No new posts VAG-COM 311.2 Diagnostic Kit Transmission, Chassis, Body & Interior
