TDI A6: AC Relay Flutter - Troubleshooting
wolle
Post18-10-2004, 11:30    Subject: TDI A6: AC Relay Flutter - Troubleshooting Quote
Hello everyone,
I have an A6 C4 with automatic climate control. I've been driving it for 4 years now. Sometime last year, the relay for the air conditioning system started intermittently failing (electrically), sometimes disconnecting and then reconnecting, etc... Then it would be gone for a few days or even longer, only to reappear again. When the relay fails, the corresponding fan also stops working.
I then had the coolant replaced, including the expansion valve. At the same time, I also had the air conditioning system evacuated. I wanted to make sure that no refrigerant was being lost through any leaks, which could have caused the pressure in the system to be at its limit. Besides, it was due for a service anyway...
However, everything was fine, and the problem was therefore not resolved.
Now there are pressure switches in the climate control system. Can anyone tell me where the pressure switch(es) is/are located?
I would like to be present with a measuring device the next time this problem occurs again.
Perhaps the switch(es) are malfunctioning.
Or does anyone have another idea, or are there any known issues with these vehicles?
Thank you and best regards.
Wool.
Translated on 24-08-2026, 4:34.
wolle
Post18-10-2004, 11:45    Subject: TDI A6: AC Relay Flutter - Troubleshooting Quote
Oh yeah... I forgot... (sorry!!!)
Okay, so the error memory is clear. The system shouldn't be overloaded either. I already had that checked after contacting support.
Translated on 24-08-2026, 4:36.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner smells bad General Tips
No new posts Relay 109 Diesel Engine Technology
No new posts Relay 109 for Audi A4 (1996): Location? Diesel Engine Technology
No new posts Relais 109: Location for 1Z? Diesel Engine Technology
No new posts Relay Location Peugeot 206 Diesel Engine Technology
