Missing needle lift sensor on AKN 2.5 TDI
Prestwick
Post28-02-2006, 0:00    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Hello everyone,
unfortunately, I recently realized that I apparently couldn't see things quite correctly. icon_question.gif
It started when I ordered an OBD2 interface from the shop and started poking around in the error memory.
The error memory for the engine informed me that the cable of the throttle position sensor was broken or that the B+ line was shorted to ground.
After I lifted the rocker cover of my car for the first time since buying it,
I thought that my more or less modest technical knowledge should be enough to
find the throttle position sensor (TPS). It wasn't a problem with my old 1z Audi.
However, with this engine, I was unable to find it. I couldn't believe it...
A look in the workshop manual showed me that cylinder No. 3 normally houses the NHG.
Since I am sure that I have found the injectors, because the piping came from the VEP, I wonder where this rascal is.
The thought occurs to me that this one was removed by one of the previous owners. Could I be right? If so, what does the connector look like? Where is it normally located?
I would be very grateful for a short tip, photo, or a hint.
I am very confused. Therefore, I hope for a quick response.
Thank you very much.
Greetings from sunny Baden
Marco
P.S. [email protected]
mullemaus
Post28-02-2006, 0:15    Subject: Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Since I am certain that I have found the fuel injectors, because the piping led away from the VEP (variable valve lift system), I wonder where this rascal is. It occurs to me that this part may have been removed by one of the previous owners. Could I be right about that?
The question is, are you serious? icon_lol.gif I believe the nozzle is located in the right bank. There's a cable connected to it. See, when you remove the cylinder head cover. icon_wink.gif
Take a closer look again; it's definitely installed in the car icon_wink.gif.
bastion
Karma: +6 / -1   Thank you, like it!
Post28-02-2006, 7:29    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
It's actually quite easy to identify. If the injector is connected to a cable, then that's it. Besides, she is taller than the others.
Herr Antje
Post28-02-2006, 7:31    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Okay, the nozzles run directly through the cylinder head cover (which you have already found icon_biggrin.gif). The NHG (Nitrogen Humidification Generator) is located on the right bank, facing forward. If you stand in front of your car on the left side, it's the middle nozzle. Under the cylinder head cover, right next to this nozzle, there is a recess in the cylinder head (on the intake side). The cable from the NHG has a half-moon shaped seal that seals this recess. Follow this cable until you find the plug.
Unfortunately, I can't explain it any better, but it should work now...
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Karma: +807 / -0   Thank you, like it!
Post28-02-2006, 10:13    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Well... how was it back then with the TDI engine and the gasoline transmission? icon_lol.gif
 File size:  42.7 KB
 Viewed:  15278 times
Herr Antje
Post28-02-2006, 10:30    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
bastion wrote:
It is actually very easy to identify. If the injector is connected with a cable, then. Also, she is bigger than the others.
The cable is not easily visible; you would need to remove the cylinder head cover to see exactly which nozzle it is connected to. Furthermore, I couldn't detect any difference in size!
Therefore, I have to defend Prestwick a little bit...
@Rainer
"TDI with gasoline transmission"?
Aktuell:
Post28-02-2006, 10:49    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
@bastionViewing profile: bastion
In the V6 TDI engine, all the injectors are the same size!
The 4-cylinder and 5-cylinder TDI engines have protruding injectors (on cylinder 3 in the 4-cylinder engines).
Post28-02-2006, 11:13    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
What do you mean by "TDI with gasoline transmission"?
A few weeks ago, someone wrote in the forum that their new used car wasn't reaching the stated top speed. Apparently, to save money, they had simply installed a readily available transmission from a gasoline-powered car, which had a much shorter gear ratio. Motto: From 2 pieces of scrap, make the car run smoothly icon_smile.gif.
Herr Antje
Post28-02-2006, 11:36    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Oh, so you were suggesting that the NHG (presumably a specific regulation or law) was actually removed. I thought it was meant to indicate that someone had written something nonsensical or irrelevant. It seems like it was meant to apply to me (a joke from my wife, see my name) icon_biggrin.gif
Aktuell:
Prestwick
Post28-02-2006, 13:52    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Hello again,
Since I didn't know that the valve cover was still on top of the fuel injectors, and all that was visible from above were the Ermedo fittings for the high-pressure connection, it's impossible to tell if everything is properly connected.
Thank you so much for helping me so quickly. I'm going to take a close look at the cable routing and the connector.
I hope I can find something there...
Marco
bastion
Post28-02-2006, 13:56    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Why are they only visible on 4-cylinder and 5-cylinder engines? Are the injectors located deeper in the cylinder head for the V6 engine?
Prestwick
Post28-02-2006, 14:06    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
Hello everyone,
For all nozzles, the high-pressure (HD) fittings are visible. They all seem to be the same length...
So far, it seems okay.
Marco.
Herr Antje
Post28-02-2006, 14:10    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
I don't know who you mean by "@", but maybe I can explain it to you.
The injectors on the V6 engine pass directly through the cylinder head, between the valves, while on other models they are arranged on the sides. Therefore, the injector also has a longer path and is largely hidden under the cylinder head cover. The connection from the high-pressure fuel pump therefore runs under the cover, away from the injector. The nozzle attachment (this plate with the two nuts) is also located under the hood.
Why can't I tell you...
Aktuell:
Post28-02-2006, 14:51    Subject: Missing needle lift sensor on AKN 2.5 TDI Quote
The V6's nozzles are visible, but they are not emphasized any *MORE* than the others.
This only applies to engines with 4 and 5 cylinders icon_smile.gif.
The other 5 injectors on the V6 engine are also "long".
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Injector Failure: VW 2.5 TDI AKN Repair Possible? Diesel Engine Technology
No new posts Needle Valve Injector Diesel Engine Technology
No new posts 1Z Needle Valve Actuator in ASV ??? Diesel Engine Technology
No new posts Needle Valve: Types, Function & Applications Diesel Engine Technology
