Golf 3 sunroof "clicks" or "makes a clicking noise"
AMB1980
Post25-07-2002, 6:34    Subject: Golf 3 sunroof "clicks" or "makes a clicking noise" Quote
Hello everyone,
My sunroof makes a 'cracking' sound when it's open or being operated. I've been troubleshooting and haven't found any loose parts, but when I press on the side (lengthwise) of the SD frame, I hear a cracking sound (it sounds like metal being bent in and then popping back out).
Okay, I wanted to ask if anyone has ever encountered this problem: I don't want to take apart the roof lining etc. only to find that the issue is somewhere else entirely.
Best regards, Alex.
Please provide the text you would like me to translate from German to English.
G3 AHU
Translated on 04-07-2026, 16:38.
Michael II
Post25-07-2002, 6:50    Subject: Golf 3 sunroof "clicks" or "makes a clicking noise" Quote
I once had the same problem.
On the sliding roof frame, there are two metal levers on the right and left sides, each with a small rubber ring pointing towards the rear. If this part is worn out or missing, the lever mechanism will no longer function properly, and you will hear a clicking sound.
Tschüss
Michael II
Translated on 04-07-2026, 16:39.
AMB1980
Post25-07-2002, 11:08    Subject: Golf 3 sunroof "clicks" or "makes a clicking noise" Quote
Thanks for the quick help, I'll check it out right after work!
Translated on 04-07-2026, 16:40.
Kusi
Karma: +8 / -1   Thank you, like it!
Post31-07-2002, 10:53    Subject: Sunroof Quote
Hello Alex,
If the small silver lever broke on yours, I might have an instruction manual somewhere on my computer with some tips for disassembling it. If you'd like, I can take a look and see if I can find it. The left part of mine was broken once. It's a bit of a hassle, but it's doable.
Kusi.
Stukov
Post01-08-2002, 1:50    Subject: Golf 3 sunroof "clicks" or "makes a clicking noise" Quote
'I experienced the same issue. It was making a cracking sound because the metal part was being pushed down too far. Every time I moved the sunroof, it would crack.' I just pulled a cable tie tight and clipped it (probably in the spot where the rubber band is usually supposed to be, but there wasn't one there for me) and it's been holding securely and quietly ever since.
Translated on 04-07-2026, 16:41.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI "Wiring Issues": Golf 3 Engine Control Problem? On-Board Diagnostics (OBD)
No new posts Golf 4: Right Front Inner Fender Liner Transmission, Chassis, Body & Interior
No new posts Accident Golf III Gti 20 years and "reference points"? Transmission, Chassis, Body & Interior
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
