Valve Hole Diameter: Find Your Rim Size Here
Go to page: 1, 2  Next
dj1
Post18-02-2005, 12:47    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
What is the diameter of the hole in the rim for the valve?
Can someone please measure a rim using a caliper?
Thank you.
DJ.
Translated on 31-08-2026, 14:15.
dj1
Post18-02-2005, 23:06    Subject: History: The Story Behind... Quote
Perhaps I'll briefly explain the background.
I bought new rims.
I also bought valves from Raid at the same time.
Problem:
The valves have a diameter of 10.65 mm.
However, the hole in the rim (for the valve) is only 8 mm in diameter.
Question: Can I simply enlarge the hole with an 11mm drill bit so that the valves fit?
Nothing should really go wrong if I try to maintain a reasonable angle.
Thank you for your tips.
DJ.
Translated on 31-08-2026, 14:16.
Günther
Post19-02-2005, 0:00    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
I wouldn't do that!
The valves are 'pulled in' during the 'installation' process, which makes them thinner.
Günther.
Translated on 31-08-2026, 14:17.
dj1
Post19-02-2005, 12:38    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
These are Raid's metal valves!
It doesn't pull it in icon_biggrin.gif.
I only need to drill from 8mm to 11mm - what's the problem with that?
I have aluminum drill bits, and the rim is also made of aluminum.
I don't understand why my wheel doesn't have a standard diameter.
I am grateful for any advice!
DJ.
Translated on 31-08-2026, 14:18.
Karma: +805 / -0   Thank you, like it!
Post19-02-2005, 12:50    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
Okay, then there's nothing against drilling it out. How do the valves seal? Is there a rubber ring behind them?
Translated on 31-08-2026, 14:19.
Post19-02-2005, 13:22    Subject: Rim Hole Size for Ve: Find the Diameter Quote
8mm
Günther
Post19-02-2005, 13:28    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
DJ
Your rim likely has the standard bore for the 'standard valve'; what 'advantage' do your metal valves offer?
Günther.
Translated on 31-08-2026, 14:20.
dj1
Post19-02-2005, 14:38    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
So, my valves have rubber seals at the top and bottom, so they should be airtight.
Here's a link to those things:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=14771&item=7953912575&rd=1&ssPageName=WDVW
Advantages of valves:
I have a polished bed, so I want flat valves.
It's strange that the valves then wouldn't have standard sizes!
DJ.
Translated on 31-08-2026, 14:22.
dj1
Post19-02-2005, 14:39    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
Günther
Translated on 31-08-2026, 14:23.
Günther
Post19-02-2005, 15:19    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
However, to inflate it, you will need an adapter that is compatible with the valve.
Otherwise, drill carefully.
Günther.
Post19-02-2005, 15:27    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
Caution!! These products did not previously have approval for use in the StVZo regulations.
Translated on 31-08-2026, 14:24.
dj1
Post20-02-2005, 13:12    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
It's strange that Raid isn't adhering to the standards, or what kind of rims are these valves intended for?
An adapter for filling was included.
DJ.
Post20-02-2005, 14:15    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
dj1 wrote:
... which rims are these valves for?
"I'm familiar with these valves from motorsports. They are used in various types of rims. These valves are only a few grams lighter and are less susceptible to centrifugal forces."
Please be aware that drilling the valve opening in your rims will void their approval. Therefore, these valves are also non-standard, so they won't fit on standard road rims without modifications.
Translated on 31-08-2026, 14:25.
ThomasB
Post20-02-2005, 15:32    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
I also have 'hidden' valves installed. And I don't believe that my tire dealer would install non-approved products, let alone drill holes in the rims.
http://www.turbotommi.de/bremse2.htm
Thomas
Translated on 31-08-2026, 14:26.
dj1
Post20-02-2005, 20:54    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
@ Thomas B
Where did you get your 'hidden' valves from?
Link?
Does anyone know of any other places where I can buy 'hidden' valves that will fit (8mm)?
DJ.
PS: Man, it's so complicated to just find 4 small valves. icon_confused.gif
Translated on 31-08-2026, 14:27.
ThomasB
Post20-02-2005, 21:25    Subject: Valve Hole Diameter: Find Your Rim Size Here Quote
I'll check tomorrow to see which manufacturer my [items] are from.
Thomas
No new posts Valve Compatibility: Do Valves Fit All Rims? Transmission, Chassis, Body & Interior
No new posts Clutch Input Shaft Diameter 1Z/AFN Diesel Engine Technology
No new posts AJM Flywheel: Outer Diameter? Diesel Engine Technology
No new posts Rim Scratch Repair: How to Fix It Transmission, Chassis, Body & Interior
