Rear Axle Bearing Wear Limit?
ObenbeiMutti
Post04-02-2005, 17:14    Subject: Rear Axle Bearing Wear Limit? Quote
'For almost 2 years, I've known that my rear axle bearings are worn out (according to the manufacturer's inspection report). In fact, the outer metallic part was heavily corroded.'
However, they didn't have any problems, as their vital signs seemed to be good.
I haven't checked recently, but now I'm noticing a 'popping' sound coming from the HA (hearing aid). It's only noticeable with larger holes, though.
I want to know: How does a worn-out HAL (Hydraulic Axial Load) manifest itself? (e.g., play in the bearing, rattling?)
b: What potential consequences could result from driving like that?
Thank you very much.
Greetings.
Translated on 14-09-2026, 12:33.
No new posts Clutch Wear: Symptoms and Replacement. Diesel Engine Technology
No new posts Rear axle bearings - 2 or 4? Transmission, Chassis, Body & Interior
No new posts Rear Axle Bearing for VW Golf III Transmission, Chassis, Body & Interior
No new posts Grease for Rear Axle Bearings: Best Choice Transmission, Chassis, Body & Interior
