Larger Turbo for 1Z Engine: Which Fits?
markVR6
Post06-02-2005, 20:10    Subject: Larger Turbo for 1Z Engine: Which Fits? Quote
Since my turbocharger might need to be replaced eventually, I was considering installing a slightly larger one to gain some more power (when combined with other modifications like injectors and a tuning chip).
Could someone perhaps tell me what might be suitable here, and more importantly, what would be a sensible option?
I actually didn't want to make any major modifications like those used on AFN components...
'Thank you very much!'
Mark
Translated on 04-08-2026, 16:50.
Post06-02-2005, 20:18    Subject: Larger Turbo for 1Z Engine: Which Fits? Quote
The answer is simple:
NOTHING.
The catalytic converter and exhaust pipe indicate that only the turbocharger from the 1Z engine is compatible.
If you want to change anything else, you'll have to replace at least these parts. However, it's questionable whether it makes sense to install a different type of wastegate turbocharger.
Just chip away at it and you'll get there.
Martin.
Translated on 04-08-2026, 16:51.
markVR6
Post09-02-2005, 17:16    Subject: Larger Turbo for 1Z Engine: Which Fits? Quote
Okay, the exhaust manifold and other things wouldn't be that bad, and the chip is already something I was considering. But what's more important to me now is that I need a new (AT) turbo anyway, so I was thinking of getting a slightly larger one at the same time...
Does anyone have any ideas which wastegate turbocharger would be the best fit?
Mark
Translated on 04-08-2026, 16:52.
Post09-02-2005, 19:15    Subject: Larger Turbo for 1Z Engine: Which Fits? Quote
What do you mean by "fit"?
With the right amount of effort, you can theoretically get any charger to work.
But when it comes to something relatively easy to install for a TDI wastegate, there's nothing better.
Quite the opposite is true for the VTG vehicles – there's a whole menagerie of different chargers available for them.
Sorry, but with the 1Z, you have a limited foundation.
Translated on 04-08-2026, 16:53.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATJ Turbo: Which Turbo Fits? Diesel Engine Technology
No new posts AFN Engine: Which PD Turbo Fits? Diesel Engine Technology
No new posts LLK for G3 AFN: Find the Right Fit Diesel Engine Technology
No new posts Which engine fits? Diesel Engine Technology
