Pre-combustion Nozzles: What are they?
Post24-06-2005, 8:12    Subject: Pre-combustion Nozzles: What are they? Quote
My T3 JX colleague has been telling me for a few days about "pre-injection nozzles" for his bus. What he then describes sounds very much like a pilot injection system for common rail systems combined with pre-injection for cooling in a turbocharged gasoline engine (so it's kind of a wild mix). icon_evil.gif
Since even my two-stage nozzles for the 1Z can't achieve a true pilot injection, I don't believe that a nozzle with a threaded tip (especially without external control) can do so.
And what sounds like a pre-cooling system, I already consider nonsense, especially with diesel engines.
He says that information about the nozzles might be available on the Henzo page on dieselsend.de, but I can't find anything there.
Does anyone know about these "WunderDuesen"?
"Thank you."
martin
Translated on 08-10-2026, 19:24.
Post24-06-2005, 8:52    Subject: Pre-nozzle: What is it? Quote
These aren't special nozzles; they're simply dual-spring nozzles, like those used for a 1Z engine, but designed for a single-cylinder Wankel engine.
The nozzle sprays a small amount initially, and then, as the pressure continues to increase, it switches over to the main injection from the pump. This process does not require any additional control.
Your 1Z does the exact same thing.
EDIT: These nozzles have already been used in various G2/G3 models. (DN0SD297)
Unter.
http://dh5eah.toxisch.net/download/g3umbau/g3poelumbau_v10.pdf
Can you read the explanation for the pre-combustion nozzle (and why it is so suitable for oil) in the section below "Nozzles"?
Translated on 08-10-2026, 19:26.
Post24-06-2005, 9:08    Subject: Pre-combustion Nozzles: What are they? Quote
Sure, you're welcome.
I also read on Henzo's website that the "pre-injection nozzle (0 434 250 138) (DN 0SD 273)" was installed in the JP models.
And I've been driving and modifying Japanese cars for 10 years, and I've never encountered a pre-catalytic converter nozzle before.
Probably, that means they also fit internally for the JP models. However, they definitely weren't included in the 4/85 and 7/87 JP models.
I'll take a look at the link.
"Thank you."
Translated on 08-10-2026, 19:28.
Post24-06-2005, 9:15    Subject: Pre-combustion Nozzles: What are they? Quote
Okay, now it's clear.
"The 'cooling off' period" was completely misunderstood by Mr. JX.
Translated on 08-10-2026, 19:29.
Jockel
Karma: +15 / -1   Thank you, like it!
Post24-06-2005, 10:20    Subject: Pre-combustion Nozzles: What are they? Quote
Enjoy your meal!
I just accidentally deleted my text, but whatever.
Pre-swirl nozzles, such as the DN0SD297, generate their pre-swirl without the use of a second vane.
(zumindest wenn sie in ein-Feder Halter eingebaut sind) über einen spez. Chamfer.
at the tap.
The theory behind using a very small pre-pulse is that it works significantly better.
It ignites and thus ensures that the main part catches fire properly; This is important when using wood chips (pöls) because wood chips burn poorly.
ignites.
Two-clip holders (like those used in the Golf III/AAZ and later installed in TDI engines) can also do that.
just about a second feather.
The single-spring holders are very easy to adjust, while the double-spring holders are not.
According to experiences shared on the Pöl forum, all VW swirl chamber diesel engines run very well with...
DN0SD297.
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 08-10-2026, 19:31.
Back to top Profile PM Email
Post24-06-2005, 11:31    Subject: Pre-combustion Nozzles: What are they? Quote
Jockel wrote:
Just now, out of sheer stupidity, I deleted my text, but it doesn't matter.
Should I comment on this now, or is it better not to...? icon_wink.gif icon_lol.gif icon_lol.gif icon_lol.gif icon_lol.gif
Pre-injection nozzles, such as the DN0SD297, create their pre-injection without a second valve.
at the tap.
The underlying function/effect is the same. The needle is lifted slightly, and a small amount of material is ejected as a "pre-shot" due to the specific grinding.
The two-stroke engine achieves this with a second injection stage.
Translated on 08-10-2026, 19:33.
Jockel
Post01-07-2005, 8:44    Subject: Pre-combustion Nozzles: What are they? Quote
Enjoy your meal!
Here are some pictures of pre-combustion nozzles:
http://f23.parsimony.net/forum49387/messages/207972.htm
Hi, Jockel.
Translated on 08-10-2026, 19:34.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
