Audi 80 Avant TDI: Durable Chip Tuning
stl73
Avatar-stl73
Post03-03-2005, 15:37    Subject: Audi 80 Avant TDI: Durable Chip Tuning Quote
"Who has extensive experience with a tuning chip installed in an Audi MKB 1Z engine, specifically with the ECU (engine control unit) number 0 281 001 185?"
Which chip was installed, and what effects were achieved?
Best regards and thank you.
Stefan.
Translated on 17-08-2026, 16:23.
Back to top Profile PM Email
Post03-03-2005, 16:57    Subject: Audi 80 Avant TDI: Durable Chip Tuning Quote
At 375,000 km, I would add a little bit (around 10 cents) and it would be fine.
With a powerful switch that allows you to normally drive with standard settings, but provides extra power only when needed for quick acceleration.
Translated on 17-08-2026, 16:25.
faz
Avatar-faz
1994 Audi 80
Post07-03-2005, 13:02    Subject: Audi 80 Avant TDI: Durable Chip Tuning Quote
Jedoch musst du noch aufpassen, da du nach dem Steuergerät den alten 1Z-Motor mit 182Nm max. Have torque.
Therefore, it includes features such as an air mass meter, a fuel injection pump with a round-shaped connector, and an external boost pressure sensor, etc.
So, you can do a lot of things here, but you can't necessarily copy everything from the "10Cent-Tuning" approach directly.
MfG faz
Audi 80 B4 Avant TDi 10/93
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts A6 Avant AVF Multitronic Chiptuning empfehlenswert? Diesel Engine Technology
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Audi A6 4F Avant Kombiinstrument, VAG-COM. On-Board Diagnostics (OBD)
No new posts Kosten: Audi 80 Avant - Querlenker Transmission, Chassis, Body & Interior
