vwSchrauber Profi-Schrauber
22-12-2009, 10:25 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
What type of injectors does the Golf 4 AGR with automatic transmission come standard with?
From a data perspective, it's nothing more than an AHU, possibly with a transversely mounted VP37 engine like in the ALH, but otherwise identical. Also, the emissions standard (EU2) is not different.
Year of manufacture: 1999.
"Thank you."
Greetings.
John. selber schrauben - statt Werkstattpfusch
Translated on 25-07-2026, 10:43.
Octavia_4x4 Schrauber
22-12-2009, 10:30 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
According to my records, the distinction between manual and automatic transmissions only starts with the ALH models.
The same nozzles were used in the AGP and AGR models, specifically:
038130201GX - Fuel injector (3 pieces)
038130201FX - Fuel injector with needle lift control (1 piece).
I haven't specified the exact nozzle diameter, but it should be possible to determine it based on the numbers provided above.
Translated on 25-07-2026, 10:44.
22-12-2009, 13:10 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
I also have the VW numbers of the owners, but what's interesting is what's inside, specifically the DSLA 150 P xxx part. If I disassemble it, check it, and then order a replacement, the car will be out of service for at least 2 days, and the customer gets nervous when they have to wait  . selber schrauben - statt Werkstattpfusch
Translated on 25-07-2026, 10:46.
22-12-2009, 14:34 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
BOSCH DSLA150P442
Repair kit for injectors, engine codes: ACV, AGR.
It's best to double-check directly with Rainer; he should be able to look into it as well. This is what my IT system found after a long search.
Translated on 25-07-2026, 10:47.
22-12-2009, 14:59 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
Ibiza1986 wrote: | | Repair kit for injectors of engine codes: ACV, AGR |
Are you sure? Usually, 4-cylinder and 5-cylinder engines don't use the same injectors because of the different injection angles. The 0.216 injectors for the AHY/AXG engines aren't the same as those used for the 1.9 engines either. MfG. Michael
Translated on 25-07-2026, 10:48.
Profile PM Garage |
22-12-2009, 23:31 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
I've checked again carefully, so while the repair kit is mentioned, I'm not 100% sure about it anymore.
If the nozzle tip set is the same, then logically the nozzle holder should also be the same – but that's not the case with AGR and ACV.
23-12-2009, 0:27 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
Ibiza1986 wrote: | | If the nozzle tip set is the same, then theoretically the nozzle holder should also be the same - but that's not the case with AGR and ACV. |
It's obvious because:
ACV = Connections for the leakage oil lines are screwed on.
AGR = Connections for the oil leak lines are crimped. MfG. Michael
Translated on 25-07-2026, 10:49.
Profile PM Garage |
23-12-2009, 0:28 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
Okay, that seems right  , so the listing from the Bosch catalog is probably correct after all.
Translated on 25-07-2026, 10:50.
patrick8549 Blaumann
Tagessuppe likes this. |
23-12-2009, 14:08 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
Should the AGR (Automatic Gearbox Regulator) with an automatic transmission not have an 11mm high-pressure component and smaller injectors than, for example, the ALH?
I believe that the AGR automatic and the ALH automatic use an 11-series pump head and nozzle tips with a size of approximately 0.154.
My pump head, which is size 11, actually comes from an ALH automatic transmission pump, if I'm not mistaken.
Quote: | | Normally, 4-cylinder and 5-cylinder engines do not have the same [characteristics] because of the different injection angle. |
And that's another rumor spread by tuners to protect themselves from competition and to sell their overpriced Bosio Motorsport products. Both 4-cylinder and 5-cylinder diesel engines have a 150-degree injection angle. That's also why they're called "DNA150"...
Best regards, Golf 4 MKB:ALH
Translated on 25-07-2026, 10:51.
mullemaus Guest
26-12-2009, 22:59 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
Should the AGR with automatic transmission not have an 11mm high-pressure component and smaller injectors than the ALH, etc.?
My 11-series pump head, if I'm not mistaken, comes from an ALH automatic pump.
That's correct!
Automatic: VE4/11E2075R712-2
Switch: VE4/10E2075R700
The nozzles should then be the specified size of 0.154.
Translated on 25-07-2026, 10:53.
slow-moe Schrauber
28-12-2009, 10:14 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
The injectors for the VW Golf 4 with AGR engine, both automatic and manual transmissions, are compatible with part numbers DSLA150P442 (0.184mm) and also work with engines designated AGP and AEY (SDI).
Nozzle for VW Golf 4 ALH engine, automatic transmission only, part number DSLA150P672 (0.154mm).
Nozzle for VW Golf 4 ALH engine, manual transmission only, part number DSLA150P706 (tolerance <0.184mm).
The Volkswagen Golf 4 with AGR seats always has the same type of fuel pump, regardless of whether it's an automatic or manual transmission: a 10mm fuel pump.
Translated on 25-07-2026, 10:55.
29-12-2009, 9:40 Subject: Golf 4 AGR Nozzles: Which Ones Are Best? |
That was also my assumption, since the AGR is only available with EU2. selber schrauben - statt Werkstattpfusch
Translated on 25-07-2026, 10:56.
