MKB ABC: Engine Start Issues After MSG Replacement (Solution)
Post10-03-2005, 14:17    Subject: MKB ABC: Engine Start Issues After MSG Replacement Quote
Author: Michael II
When replacing the engine control unit (ECU) with part number 4A0 907 473T, the coding must be changed to 00071.
Cause:
The control unit 4A0 907 473T is compatible with several types.
"Example of recoding:"
8DTA239584, ABC 193609, HS, Encoding 00083.
The code 00083 must now be changed to 00071.
Please provide the text you would like me to translate from German to English.
Bye.
Michael.
Translated on 31-10-2026, 5:04.
Ratings - MKB ABC: Engine Start Issues After MSG Replacement
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel and temperature gauge; worse after repair :-( Transmission, Chassis, Body & Interior
No new posts Blue smoke on engine start Diesel Engine Technology
This topic is locked, you cannot edit or reply. Check Engine Light On After Start? Diesel Engine Technology
No new posts Engine Start Problem: Strange Issue? Diesel Engine Technology
