LMM - and Resistance
Karl
Post22-08-2002, 18:40    Subject: LMM - and Resistance Quote
Hello!
On my LMM, there are 2 terminals and a resistor symbol.
For what is this intended and what value can be put in it?
My engine is a 1.9, 81kW, AHF, manufactured in 1999.
Hi Karl
http://members.chello.at/35fd001/DCP_0910.JPG
Post22-08-2002, 21:28    Subject: What do you want to achieve? Quote
Okay, I understand. Here's the translation, keeping all exactly as they are:
erstmal verstehe ich Deine Absicht nicht.
Further, I cannot identify any resistance symbol in the photo.
Generally, it should be stated that the LMMs are calibrated from the factory in such a way that no further adjustments are required - on the contrary, they would disrupt the mixture calculation.
If an LMM (Linear Motor Controller) is not functioning correctly, you can try cleaning it with brake cleaner spray before replacing it.
Gremlin
Post22-08-2002, 21:39    Subject: Re: What do you want to achieve? Quote
Uhh...
Do you see the two metal 'clamps' on the right side of the rubber seal?
these two brackets are connected to the resistance symbol...
I'm also wondering what's planned for that...
See you, Gremlin
Post22-08-2002, 21:51    Subject: Re: What do you want to achieve? Quote
Gremlin wrote:
Do you see the two metal "clamps" on the right side of the rubber seal?
The two brackets are clearly visible, but a resistor symbol?
This is a rectangle with one connection line on each of the narrow sides, which probably should lead to the brackets here??
Well, perhaps we're also experiencing the "ink blot effect" here: everyone sees something different...
The clamps might possibly be used to control certain internal stresses... purely a hypothesis on my part, as nothing "external" should definitely be clamped on in normal operation.
Rudi
Post22-08-2002, 21:58    Subject: LMM - and Resistance Translating...
vermutlich ein Abgleichwiderstand, um den LMM an andere Randbedingungen anzupassen.
@Karl:
Wenn Du magst, kannst Du ja mal ein paar Widerstände (z.B. 10k, 47k, 100k) dazwischenhängen und messen, inwieweit sich das Ausgangssignal ändert (Spannungswert).
Wenn sich keine Änderung der Ausgangsspannung ergibt, wär der Widerstand auch noch als Teil eines Filters denkbar, über den das Ansprechverhalten des LMM geändert werden kann.
Gruss Rudi
Georg_G
2012 Volkswagen Golf
Post23-08-2002, 0:15    Subject: LMM - and Resistance Translating...
[Translating...]
Hallo..
LMM für TDI's und Benziner sind fast gleich. Der Benziner_LMM besitzt aber an dieser im Bild zu sehenden Stelle noch einen Temperaturfühler für die Ansauglufttemp. Bei TDI-LMM's ist dieser nicht dabei.
So zumindest bei den neueren LMM's.
Gruss, Georg
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Pedal Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Increase idle speed - AFN - using VA.G-COM or resistor Diesel Engine Technology
No new posts Widerstand des Zündkreises Airbag Golf? On-Board Diagnostics (OBD)
No new posts Resistance Wattage Between Pin 4 & 7 (10c) Diesel Engine Technology
