ESP VP37 Removal: AEL Engine (A6 2.5 TDI)
Burki
Post22-11-2005, 15:06    Subject: ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Quote
'Don't yell at me, I have a really simple question: How do you access the rear Allen screw on the fuel injection pump mounting bracket (located between the engine block and the pump body)? As far as I know, there's only one Allen screw; the other three are hex screws.'
Is there a special tool for that? I can't reach it with my extensions because the vacuum pump is in the way.
Best regards, Burkhard.
Translated on 28-09-2026, 4:48.
klopfer
2007 Audi A4 Avant
Post22-11-2005, 22:18    Subject: ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Quote
Okay, there are 3 hex screws and 1 Allen screw. I always use a small ratchet with two or three extensions for the Allen screw. A larger ratchet won't fit in there. It's a real pain every time, and I often tear or burn my fins, but it works.
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 28-09-2026, 4:49.
Burki
Post23-11-2005, 17:05    Subject: SEO-Optimized Title: **Best Practices: A More Elegant Approach** Quote
Hi, thanks for the tip, I'll give it a try. I've tried something similar before, but it didn't work out and I had to stop. You really have to lubricate your fingers with Vaseline to be able to reach it...
icon_lol.gif I thought there might be a trick or a more elegant method for that. So, if anyone knows something, my fingers would be happy!
Translated on 28-09-2026, 4:50.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Issue with starting the spray gun, model VP37 Diesel Engine Technology
No new posts Acceleration Problem: AFN Engine Troubleshooting Diesel Engine Technology
No new posts Rear side window modification for Audi C4 Avant? Transmission, Chassis, Body & Interior
No new posts Can the VP37 distribution body be removed without disasse... Diesel Engine Technology
