Steering wheel vibration when accelerating?
TDI 180
Post25-08-2002, 23:42    Subject: Steering wheel vibration when accelerating? Quote
'For some time now, I've been experiencing a slight vibration in the steering wheel when accelerating (specifically during acceleration in 5th/6th gear at speeds of 120-150 km/h). It's also noticeable in other gears.'
I already took it to the workshop, and they said the wheels need to be rebalanced.
They just did that, and they changed the tires from front to back.
The stuttering is still there!
I think there might be an imbalance in the drive shaft or perhaps a bearing issue.
What do you think?
I've been experiencing this jerking for quite some time, but I thought it might be due to the high torque and power output becoming noticeable.
I'm looking forward to reading your contributions!
Sebastiaan.
Translated on 16-07-2026, 7:34.
MelleTom
Post26-08-2002, 10:44    Subject: Steering wheel vibration when accelerating? Quote
'The same problem as with the brakes: the wheel hub, wheel bearing, or driveshaft stub is bent. Did you perhaps slide into something on the edge during the winter?'
Translated on 16-07-2026, 7:36.
schnupfi
Post26-08-2002, 11:18    Subject: Steering wheel vibration when accelerating? Quote
I'm having a problem too. I think it's called 'flat spots' (that's what I believe the term is). The car has been sitting for 4 months and I haven't moved it.
This can also happen during hard braking (without ABS) if the wheels lock up and you just slide, which is then known as brake locking or skidding.
It could also be a wheel bearing, but if that were the case, you would likely hear a loud noise coming from the front.
Schnupfi.
Translated on 16-07-2026, 7:37.
tito
Post26-08-2002, 11:32    Subject: Steering wheel vibration when accelerating? Quote
The rims might have a runout, which can lead to extreme vibrations.
Even the tires can, if they are of poor quality (like the factory-installed tires from VW, for example icon_biggrin.gif, I've experienced this myself), develop a radial runout relatively quickly.
With relatively consistent vibrations that change or intensify depending on the speed, I would initially suspect the wheels.
Translated on 16-07-2026, 7:38.
TDI 180
Post26-08-2002, 12:07    Subject: Steering wheel vibration when accelerating? Quote
MellTom: No, I haven't had any 'accidents' in the winter (or summer), it can't be that.
Schnupfi: My car is never (almost never) out of commission for more than 1 day; I drive 60,000 kilometers a year. It wasn't a full stop; I didn't do that, and I have ABS.
Tito: The rims have no runout; you only feel vibrations when accelerating (during acceleration). The tires are good, they're Continental Sport Contact 2s. The wheels have been rebalanced and swapped from front to back. None of that helped.
I know it's not easy, but I suspect it might be the wheel bearing or possibly the driveshaft.
Sincerely,
Sebastiaan.
Translated on 16-07-2026, 7:39.
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Vibration: 6X1 MJ 2002 Doku & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log files related to the "thinking pause" issue when acce... Upload
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Wobbly Steering Wheel When Braking? Causes & Fixes Transmission, Chassis, Body & Interior
No new posts 1.9 TDI: Engine Jerking & Troubleshooting Diesel Engine Technology
