long 5th gear on asd
cksIT
Post08-07-2005, 12:06    Subject: long 5th gear on asd Quote
I've found the old thread, but there's nothing about a longer gear for the asd gearbox inside...
Was about a longer one, if so, what gear and part number?
Thank you in advance.
Post08-07-2005, 13:24    Subject: long 5th gear on asd Quote
Be happy, at least you have ASD.
My CTN (for the combo) is significantly shorter.
The CYP from AFN is longer.
That's not correct, Correction see below!!!
Look:
http://www.dieselschrauber.de/GKB.html
Frank A.
2000 Volkswagen Golf
Post08-07-2005, 15:44    Subject: long 5th gear on asd Quote
dieselmartin wrote:
You should be happy just having ASD.
Look:
@dieselmartinViewing profile: dieselmartin Are you sure you helped him? The CYP is not longer than the ASD...
@cksITViewing profile: cksIT
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
02A 311 361 AM; 02A 311 158 AF = 28/40 = 0.7
02D 311 361; 02D 311 158 = 32/47 = 0.681
02Z311158A; 02Z311361A = 27/41 = 0,658 (here, the spring of the gear mounting must be modified)
I, however, assume no liability...
Best regards, Frank
'00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe
cksIT
Post12-07-2005, 6:40    Subject: long 5th gear on asd Quote
ok, danke
I need to get my control unit repaired first, and then I'll take a look. But I'm already itching to get started.
Post12-07-2005, 10:57    Subject: long 5th gear on asd Quote
Then the table is incorrect!
ASD Axis: 60:19
ASD 5th: 33:46
CYP Axis: 60:19 (same)
CYP 5ter: 29:39
Post12-07-2005, 11:01    Subject: long 5th gear on asd Quote
Here's the comparison: ASD(normal G3)-CTN(Variant)
http://people.freenet.de/golf-schrauber/ASD-CTN.jpg
Frank A.
Post12-07-2005, 13:22    Subject: long 5th gear on asd Quote
I don't know what you want with your CTN, the man has an ASD gearbox and wants to make it longer.
The table is correct, and for you, I will also write the beginning of the sentence from above until the end: The CYP is not longer than the ASD but SHORTER (the exact translation you have already found out).
Best regards, Frank
Post12-07-2005, 13:50    Subject: long 5th gear on asd Quote
Hello Frank
Even though I initially felt a bit foolish, I've found my calculation error.
I was looking at the teeth of the first garden too much.
ASD, CTN and CYP have a 60:19 gear ratio.
The fifth is:
CTN 34:45 = 0.7555
ASD 33:46 = 0.714
CYP 29:39 = 0.744
So, we definitely have an order (in the mathematical sense) CTN -> CYP -> ASD
Is the ASD already the longest 02A gearbox?
Frank A.
Post12-07-2005, 14:12    Subject: long 5th gear on asd Quote
Hello Martin,
to annoy you a little more: 33:46 is 0.717. (yes, I know it was just a trick)
Yes, I believe it's the longest standard combination. The longer 5th gears from other gearboxes, see above.
Best regards, Frank
P.S. I apologize if my tone came across as harsh, however, I also found your first response to the original question to be somewhat pointless (At least you have ASD, so be grateful). My CTN (for the combo) is significantly shorter.
cksIT
Post14-07-2005, 13:31    Subject: long 5th gear on asd Quote
Sorry, I didn't have the email notification turned on.
so, wenn ich das richtig verstanden habe, es gibt keine längeren Gänge serienmäßig...
What about the ones mentioned above, can they be easily installed?
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts long 5. How to change the timing belt on a VW Golf 3 TD Diesel Engine Technology
No new posts 4-Speed Automatic Transmission Diesel Engine Technology
No new posts Converting a Caddy 5-speed to a 6-speed Transmission, Chassis, Body & Interior
No new posts Could not engage gear Diesel Engine Technology
