Bazi103
2012 Volkswagen Passat Premium Support
16-09-2013, 14:15 Titel: Westfalia AHK Codieren an Passat B7 |
Hallo
Ich habe Probleme die Westfalia AHK zu Codieren:
Passat B7 BJ 2012
Monday,16,September,2013,12:32:18:27123
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
62 69 72
VIN: WVWZZZ
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Sporadic communication error 1000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Not registered 0001
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PA HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 2472
Revision: 41H28--- Serial number: 00000000000000
Coding: 001D0012042401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018PA 003004
ROD: EV_ECM20TDI01103L906018PA.rod
VCID: 78F58B25C3BAB8D818B
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3509
Revision: 05551213 Serial number: 00001206050547
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 244D8F55E7B20C38643
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AF HW: 3AA 614 109 AF
Component: J104 C2 450M V403 0024
Revision: --H07--- Serial number: 00000005890960
Coding: 0006579
VCID: 71E3B60168C0E990DF5
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_VW46.rod
VCID: 75EB8211D4A8C5B003D
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 G HW: 3AA 937 087 G
Component: BCM PQ47 H 421 0464
Revision: BB421001
Coding: 0008000000000000009800805400816403510088426D85606480C7200041
VCID: 3E795D3DA91E46E8127
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 31051 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150612 05 54 0403
Coding: 02302A
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261215802156
Coding: 108102
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E795D3DA11E46E8127
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__11R VW10 HI 2118
Revision: 24017000 Serial number: 003LDPC9TJ8A
Coding: 0012626
VCID: 4E990DFDD9BED668E27
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120617202003
Coding: 199A250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_VW46.rod
VCID: 6FE7B079B6F4FF60C91
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 870 J HW: 3AA 920 870 J
Component: KOMBI H05 0705
Coding: 161F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
VCID: 39734E21B83061D0275
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Mileage: 14810 km
Date: 2013.14.11
Time: 15:51:15
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 120612F1000927
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 418326C1D8E039106F5
2 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 14810 km
Time Indication: 0
Date: 2013.14.11
Time: 15:51:15
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 11
Mileage: 14810 km
Time Indication: 0
Date: 2013.14.11
Time: 17:20:00
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: F6E9051D81AE4EA88A7
Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 N HW: 3C0 035 279 N
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5929114
Coding: 000004110400110000011301
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS_VW46.rod
VCID: 2E596D7D717EB668827
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005158196
Coding: 0200B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 356B4211942885B0C3D
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795
Component: J388__TSG-HL 004 0501
Serial number: 00000002991298
Coding: 010090
1 Fault Found:
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Mileage: 14810 km
Date: 2013.14.11
Time: 15:51:16
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.310 1101
Revision: 1AH03735 Serial number: 00121630155301
Coding: 0000258
VCID: 3D7B5A3164185DF00BD
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 045 0634
Coding: 0091020052830E76340494157C084F0B605801
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 00000008
VCID: EFE730793EF47F60491
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005184384
Coding: 0200B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 3669451D892E8EA8CA7
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794
Component: J389__TSG-HR 004 0501
Serial number: 00000002978600
Coding: 010090
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Mileage: 14810 km
Date: 2013.14.11
Time: 15:51:16
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000281389
Coding: 0022167
VCID: 3669451D412E8EA8CA7
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 K
Component: Batt.regelung H40 1632
Coding: 030F1859
VCID: F1E3360128C069905F5
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030451967
Coding: 0100000100000000
Shop #: WSC 00000 000 00000
VCID: 30657305634AA09890B
End ---------------------------------------------------------------------
Profil PN Garage |
Mitglied seit: 12.04.2002 Beiträge: 18086 Karma: +797 / -0 Wohnort: St.Gallen 2018 Volkswagen T6
16-09-2013, 14:53 Titel: Westfalia AHK Codieren an Passat B7 |
Ja und was genau geht nicht? Bitte Fehlerbeschreibung...
Was wurde wo schon geändert/umcodiert?
Profil PN WWW Garage |
Herbert Profi-Schrauber
16-09-2013, 14:55 Titel: Westfalia AHK Codieren an Passat B7 |
Ich habs mal als neues Thema eingestellt.
Hier der Link zu dem "alten" Thema.
/viewtopic.php?t=24420&highlight=freischalten
Bazi103
16-09-2013, 14:59 Titel: Westfalia AHK Codieren an Passat B7 |
Erstmal bekomme ich das Trailer Steuergerät 69 nicht angemeldet.
Finde da nichts wo ich ein Häckchen setzen kann was das Anhängersteuergerät anmeldet.
Steht ja oben im Scan drin :69-Trailer -- Status: Not registered 0001
Wo muss die AHK bei genau meinem Auto noch angemeldet werden?
Dann die vielen Fehler die seit dem AHK Anbau da sind.
Codiert wurde noch gar nichts.
Nach der Westfalia Anleitung gehts gar nicht.
Profil PN Garage |
Autoservice Profi-Schrauber
16-09-2013, 15:54 Titel: Westfalia AHK Codieren an Passat B7 |
Zuerst mal Rainers Post im verlinktem Thema lesen.
Dann teilst du uns mit, was du bisher genau versucht hast.
Stichwort: Den CAN Gateway zuerst.
Bazi103
16-09-2013, 16:11 Titel: Westfalia AHK Codieren an Passat B7 |
Zuerst alles nach Westfaliaanleitung verbaut
und verdahtet. 3x Dauerplus 1x Zündplus
Bremslichtleitung und 2x can aus Bordstecker raus und zum Ahk
Modul duchgeschliffen.
Masse ans Ahk Modul.
Dann mit vcds 19 can dann 7 Lange Codierung angewählt.
Jetzt wie in der Westfalia Anleitung geschrieben das Häckchen
bei Ahk verbaut setzen versucht. Und da bin ich nicht weiter gekommen.
Im SG 10 habe ich die Möglichkeit gefunden. Manual Abnehmbar AHK
anzuwählen. Habs auch gemacht.
Habe mir grade mal einen Anhänger ausgeliehen.
Die Beleuchtung funktioniert. Auch die PDC zeigt den AH im
Display an. Piepst beim Rückwärtsgang auch nicht.
Profil PN Garage |
16-09-2013, 18:20 Titel: Westfalia AHK Codieren an Passat B7 |
Zitat: | Jetzt wie in der Westfalia Anleitung geschrieben das Häckchen
bei Ahk verbaut setzen versucht. Und da bin ich nicht weiter gekommen. |
Warum? Screenshot?
Bazi103
Profil PN Garage |
16-09-2013, 19:56 Titel: Westfalia AHK Codieren an Passat B7 |
Warum englisches VCDS wenn man kein Englisch kann ?
Röter als rot geht schliesslich nicht.
Du musst auf "Installation List" klicken, steht da.
Profil PN Garage |
Bazi103
16-09-2013, 20:17 Titel: Westfalia AHK Codieren an Passat B7 |
Weil ich nur noch englische Versionen als Update für mein 2006 gekauften VAG COM Set erhalte.
In der Anleitung steht 007 Coding
Und da ich nicht viel falsch machen wollte habe ich lieber nachgefragt
Über Installation List hats funktioniert.  Danke
Jetzt sind beim Scan oben nur noch SG 17, 42,52 rot
Sonst ist kein Fehler mehr da.
Profil PN Garage |
16-09-2013, 20:41 Titel: Westfalia AHK Codieren an Passat B7 |
Zitat: | | Jetzt sind beim Scan oben nur noch SG 17, 42,52 rot |
Bitte mal alle Fehler löschen...
17-09-2013, 9:32 Titel: Westfalia AHK Codieren an Passat B7 |
Ich meinte dieses "rot".
| Beschreibung: |
| Dateigröße: |
25.98 KB |
| Angeschaut: |
7478 mal |
Profil PN Garage |
