VW Passat 3b6 2.0 TDI (BGW) measuring blocks
ormowiec
Beitrag09-09-2009, 14:15    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
At first, i'm sorry for writing in English - my knowledge of German is very poor (passing the anti-spam questions was real hardcore icon_biggrin.gif )
I'm looking for standard values of engine measuring blocks. Engine code BGW, VW passat variant 2.0 TDI, 2004 with DPF. I'm suspect PD's are dying (BIP's in 023 flirts up to 40)
ORMO
Steffen W
Beitrag09-09-2009, 20:25    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
standard values of engine measuring block MWB 23=
-100 to +100
Passat Variant BGW 2005
Karma: +796 / -0   Danke, gefällt mir!
Beitrag09-09-2009, 21:43    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
Just look in your VCDS label file...
ormowiec
Beitrag10-09-2009, 9:37    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
At first, thanks for reply
I've got VCDS 805.4-PL and 908-EN and there is no label file for this engine icon_sad.gif
-100 to +100
Well, in fact i was looking for this block vals icon_smile.gif thank you very much. Are you shure BIP has such a big range in this motor? As far as I know, typical TDI-PD it amounts +-30
[Edit Admin: I think there is absolutely no need to link to some file hosters as the attachment function in this forum is inteded for this purpose.]
ORMO
one more question
004.4 = cam/crankshaft synchro, like in 1.9 TDI-PD?
Steffen W
Beitrag10-09-2009, 21:16    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
ormowiec hat folgendes geschrieben:
The name of the labe file is 038-906-016-BGW.lbl.Its in the "labels" directory.
And yes,iam sure +100 to -100.
ormowiec
Beitrag11-09-2009, 8:46    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Zitieren
Well, i'm shure there is no such file in my VCDS labels. Nothing with *BGW*
Keine neuen Beiträge Doku Passat MKB AVB, Kraftstoffverlust Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Motorentechnik
Keine neuen Beiträge MFL Passat 3BG Bordnetze, Fahrzeugelektrik, Multimedia
Keine neuen Beiträge Log Passat v6 TDI Roh Upload
Keine neuen Beiträge Kurvenlicht Passat 3C Getriebe, Fahrwerk, Karosserie und Innenraum
