Water Leakage: How to Seal Doors Effectively
Holger247
Post08-03-2007, 8:52    Subject: Water Leakage: How to Seal Doors Effectively Quote
I have a water leak coming in through a rear door (Volkswagen Golf IV).
The door is sealed to the interior by a profiled metal panel that houses window lifters, etc. This panel is screwed to the inside of the door and sealed with a gasket made of some kind of foam.
This sealing strip is damaged in several places and can only be purchased as part of the complete metal profile.
What would you use to seal that? What do you think about using automotive silicone?
I'm also surprised that so much water is getting into the door. I think the water is coming in through the window seals, as there are small gaps in the lower corners. Perhaps I need to replace the window seals?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 21-10-2026, 4:47.
Jochen_145
Post08-03-2007, 10:01    Subject: Water Leakage: How to Seal Doors Effectively Quote
This issue is very well known at Seat.
Dieselmartin and I were discussing this.
The sealing cord is available for purchase. Martin successfully used this method.
I used automotive silicone and it's been working very well so far, but I know that if I ever need to work on the doors again, it won't be as easy to remove.
Why don't you read a book?
/viewtopic.php?t=13344&highlight=seat+leon+turbo
When using silicone, be generous with it and only roughly wipe away any excess. This is the only way to ensure that everything is properly sealed.
Best regards, Jochen.
p.s. A search would also have been helpful in this case icon_smile.gif.
Translated on 21-10-2026, 4:49.
Holger247
Post08-03-2007, 10:45    Subject: Water Leakage: How to Seal Doors Effectively Quote
Okay, I'll try to get my hands on that sealing cord.
Can someone verify the part number? I tried to read it from the Seat Leon PDF.
AKD 49701004R10
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 21-10-2026, 4:50.
Post08-03-2007, 11:29    Subject: Water Leakage: How to Seal Doors Effectively Quote
PDF ???
Why aren't you clicking on the PPT in my thread?
 File size:  22.16 KB
 Viewed:  4638 times
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seal AGR cooler bypass valve on CR-V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Door Noises: Documentary & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Water ingress door Passat 3B Transmission, Chassis, Body & Interior
No new posts How to properly unclip new wiring harnesses? Transmission, Chassis, Body & Interior
No new posts Seal Tandem Pump: How To & Best Practices Diesel Engine Technology
No new posts Seal Hubdüse SWA: How to & Best Practices Transmission, Chassis, Body & Interior
