Golf4 Variant: Adjust Comfort Module with VDS-PRO
hr3
Otter likes this.
Post27-06-2007, 12:58    Subject: Golf4 Variant: Adjust Comfort Module with VDS-PRO Quote
I upgraded both a Variant 2000 and a Limo 2003 by replacing the comfort control unit for central locking with a system that includes power folding mirrors. The Limo is working perfectly.
The variant lock engages when opening the front doors or the tailgate. I mistakenly installed part numbers 1J0 959 799 AH 04U and 002, but it's likely that 048 would have been the correct part.
VAG-COM settings are not helping.
Does anyone know if and how it's possible to modify the values using VDS-PRO?
Can someone pull a dump from machine 048?
Can someone make changes in the North German region?
Thank you for all the information.
Translated on 24-08-2026, 17:48.
mullemaus
Post27-06-2007, 16:38    Subject: Golf4 Variant: Adjust Comfort Module with VDS-PRO Quote
Since VDS/VDC-Pro is not freeware and cannot be purchased, no one will own it. icon_wink.gif If you obtain it illegally, you must deal with any consequences on your own.
Translated on 24-08-2026, 17:49.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Remotely control the window lifters in a VW Golf4 Variant... On-Board Diagnostics (OBD)
No new posts Car-Hifi Einbau + Doppelter Ladeboden Golf4 Variant Transmission, Chassis, Body & Interior
No new posts VAG-COM: Airbag Check & Diagnosis On-Board Diagnostics (OBD)
No new posts AGR beim 1Z mittels VAG-Com On-Board Diagnostics (OBD)
