1Z: Maximize Your Performance
Eugli
Post16-12-2002, 19:47    Subject: 1Z: Maximize Your Performance Quote
I have been following your discussions and have come to a conclusion.
'That you are probably the only ones who could help me.'
When I drive uphill under full load, and the engine has to work hard, it shakes violently.
Replacing the voltage supply relay 109 proved to be the correct solution.
It has been identified, but the problem is not completely resolved.
The error memory is clear now, even though it previously showed me a defective engine control unit. icon_eek.gif
I would be happy to hear any ideas anyone might have.
Translated on 03-10-2026, 6:19.
Post16-12-2002, 19:58    Subject: Needle Valve: Definition & Function Explained Quote
Hi.
The needle valve actuator often causes jerky movements.
Test: Bring the engine to approximately 3000 rpm while it's idling, and tap the longer fuel injector with a tool.
If the engine starts to sputter, it's most likely the NHG (noise, heat, and vibration) system.
Is the fuel filter part of the maintenance interval?
Do you have VAGCOM available, or can you perform diagnostic tests that record data such as the fuel injection timing?
Translated on 03-10-2026, 6:20.
Eugli
Post16-12-2002, 21:16    Subject: 1Z: Maximize Your Performance Quote
Wow, that was fast.
I'm going to replace the diesel filter this weekend. It's currently at 51,000 km.
inside.
If the needle valve actuator causes jolting or jerking when the engine is backfired, it is worn out.
Okay, good to know. I'll try it tomorrow.
Can it wear out faster due to poor filter characteristics?
(The previous owner was probably negligent about maintenance), or is that the case at 260,000 km?
normal?
Translated on 03-10-2026, 6:22.
Eugli
Post16-12-2002, 21:19    Subject: 1Z: Maximize Your Performance Quote
I forgot.
Of course, I can also monitor the injection start settings while the vehicle is in motion.
I think it's ad group 04.
Translated on 03-10-2026, 6:23.
koenig
Post17-12-2002, 7:02    Subject: 1Z: Maximize Your Performance Quote
Hello Ulf,
I know it's a silly question, but where is the fuel injector located on the AFN engine?
'My car also started doing that at a whopping 120,000 km! Is that normal? The regular service has always been done!'
Thank you.
Best regards, Florian.
Post17-12-2002, 8:09    Subject: 1Z: Maximize Your Performance Quote
koenig wrote:
Hello Ulf,
"I may not be Ulf, but I'll just answer for now."
The NHG is the "large" injector nozzle with the cable attached to the third cylinder.
Translated on 03-10-2026, 6:24.
DocSnydor
Post17-12-2002, 10:11    Subject: 1Z: Maximize Your Performance Quote
Another one with stuttering...
You could stop by sometime.
www.tdi-ruckeln.de
You are not the only one (it's a weak comfort, I know icon_cry.gif).
Translated on 03-10-2026, 6:25.
joergs
Post17-12-2002, 12:34    Subject: 1Z: Maximize Your Performance Quote
@eugli
I've experienced something similar. I was almost desperate. Eventually, I soaked the Mass Air Flow sensor (MAF) in brake cleaner, and after that, the problem disappeared. Interestingly, there was no error code in my system!
Eugli
Post17-12-2002, 18:48    Subject: 1Z: Maximize Your Performance Quote
'Im' is a German word that can have several meanings depending on the context. It can be a contraction of 'in dem' (in the), 'im' (in the), or 'am' (at the). It can also be a possessive pronoun, meaning 'his' or 'her.'
Here are some examples of how 'im' can be used:
* 'Ich bin **im** Haus.' (I am **in** the house.)
* 'Das Buch ist **im** Regal.' (The book is **in** the shelf.)
* 'Er ist **im** Urlaub.' (He is **on** vacation.)
* 'Das ist **mein** Auto.' (This is **my** car.)
* 'Das ist **sein** Haus.' (This is **his** house.)
If you can provide more context, I can give you a more specific translation of 'im.'
Translated on 03-10-2026, 6:26.
Post17-12-2002, 19:05    Subject: 1Z: Maximize Your Performance Quote
Eugli wrote:
Hey, what do you mean by "imm"?
not "imm" but LMM=Lairmassmeasurer
Translated on 03-10-2026, 6:27.
Eugli
Post20-12-2002, 9:38    Subject: 1Z: Maximize Your Performance Quote
Those who can read have a clear advantage.
I visited TDI-Ruckeln.de and found a 100% accurate diagnosis of the problem.
Thank you everyone.
See you next time!
Post20-12-2002, 15:35    Subject: 1Z: Maximize Your Performance Quote
Eugli wrote:
I was at TDI-Ruckeln.de and found a 100% accurate cause of the error.
Hi.
Then let's not die here like fools!
What was it?
Translated on 03-10-2026, 6:28.
Eugli
Post22-12-2002, 11:53    Subject: 1Z: Maximize Your Performance Quote
In the forum, everyone also voted for the NHG, and after you told me...
I also had that error when I was describing the test.
I found exactly my car's year and model (1Z) on TDI-Ruckeln.de, and it also has a...
100% accurate error description.
But mine isn't finished enough yet for an investment to be worthwhile.
With 260,000 km on the odometer, it's rare that someone drives at full throttle consistently.
There's definitely nothing that can beat a forum like that.
Thank you very much.
Translated on 03-10-2026, 6:29.
edward
Post20-01-2003, 16:46    Subject: 1Z: Maximize Your Performance Quote
We are still experiencing that annoying 'one-time jolt' problem, similar to the one described above.
I now finally have access to VCDS (Vag-Com) and would like to know which measuring blocks I should log to help narrow down the problem.
Translated on 03-10-2026, 6:30.
Post20-01-2003, 17:05    Subject: 1Z: Maximize Your Performance Quote
The needle lift sensor tells the EDC when the injection process has started.
Does that make sense? / Does that click?
Translated on 03-10-2026, 6:31.
edward
Post20-01-2003, 18:39    Subject: 1Z: Maximize Your Performance Quote
No further questions :-).
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Engine Tuning: Maximize Performance Diesel Engine Technology
No new posts Full-load trucks AFN 1500-1900/min, only with hot PÖL Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
