Reverse Gear Not Working: Doku Sharan Repair (Solution)
Michael II
Post05-03-2003, 12:48    Subject: Reverse Gear Not Working: Doku Sharan Repair Quote
Manual transmission.
Reverse gear cannot be engaged.
The affected gearboxes were manufactured between September 1, 1998, and October 21, 1998.
Cause:
Due to unfavorable tolerance effects on the locking unit for the reverse gear, the shift lever may become stuck and prevent shifting into reverse.
Solution:
In the event of a complaint, disconnect the control cables from the gearshift lever on the transmission. If a fault is detected in the shifting mechanism/gearshift lever, the transmission shift mechanism No. 006 311 682 must be installed.
Tschüss
Michael II
Translated on 04-08-2026, 21:06.
Ratings - Reverse Gear Not Working: Doku Sharan Repair
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reverse Gear Sharan TDI Automatic Not Working Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. ABS Sharan, year 2006, error cannot be fixed Transmission, Chassis, Body & Interior
No new posts Golf 4: How to Enable/Disable ABS? On-Board Diagnostics (OBD)
No new posts Grinding noise in reverse Diesel Engine Technology
