Airbag control unit replaced, now error 00589.
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
alexmulder
Post08-04-2008, 22:40    Subject: Airbag control unit replaced, now error 00589. Quote
Hello everyone,
In my T4, the airbag control unit was defective, according to VAG-COM. Error codes 65535 and 00532. I was able to fix error 00532, which was a broken cable at the alternator connection. Although I could delete the error codes with VAG-COM, they kept reappearing. That's when I realized that my brother has a Golf 3 1.9 TD and he has the same airbag control unit. So I took it out and compared the part numbers. Both control units were identical. Part number 6N0909603E, and there were no error codes stored in the Golf. So I installed it in the T4 and connected it. Now I have error message 00589, "Passenger airbag resistance too high." The annoying thing is that the T4 doesn't even have a passenger airbag. I have therefore deactivated the passenger airbag, but the error cannot be deleted. Can someone help me delete the error? It should actually be possible to clear it by coding the control unit, but I don't have the login code. And if so, how do I re-code it? Does anyone have any advice?
Ah, that's a TF 1.9 Ltr ABL engine, manufactured in 1996. As mentioned, the airbag control units are identical.
Thank you.
Alex
Wiesel
dieselschrauber likes this.
Post09-04-2008, 14:51    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
zum deaktivieren des Beifahrerairbag wie folgt vorgehen:
- Airbag STG (15)
- Anpassung (10)
- Kanal auswÀhlen (01)
- Anpassungswert (00001; 00000 wÀre zum erneuten Aktivieren)
Viel Erfolg
Gruss Micha
alexmulder
Post09-04-2008, 17:59    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
Hallo Micha,
das hatte ich schon gemacht, der Fehler bleibt aber, ich nehme mal an das er einen Widerstand vom Beifahrerairbag erwartet. Ich weiss auch welche Kabel das am Stecker zum SteuergerĂ€t sind (5&6) aber ich weiss nicht welchen Widerstand ich dazwischen klemmen muß. Ich meine mal etwas von 2,5 Ohm gehört zu haben, kann das jemand bestĂ€tigen?
Gruss
Alex
Wiesel
Post10-04-2008, 11:36    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
Hallo Alex,
das mit dem Widerstand stimmt (wobei ich dir zum Wert nichts sagen kann).
Offiziell wird beim deaktivieren der Airbag (zusÀtzlich zur Deaktivierung im STG)
abgeklemmt und an seiner Stelle ein Widerstand 1H0 998 521 B bzw. 3B0 998 521 B (je nach Fahrgestellnummer) verbaut.
Kostenpunkt der WiderstĂ€nde: ca. 30€
Gruss Micha
R.M.
Karma: +14 / -0   Thank you, like it!
Post10-04-2008, 11:52    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
Oder 0,05 Euro selbst in der Elektronik-Apotheke namens Conrad ... und dann noch ein StĂŒckchen Klebeband. Das soll jetzt keine Anleitung zur Frickelei an sensiblen, sicherheitsrelevanten Systemen sein aber der VW-Preis ist ja wohl eine Frechheit. icon_evil.gif
Nachtrag: Falls Du es doch vor hast (was ich nicht gut finde) versuche 2,2 oder 2,7 Ohm und löte den Widerstand fest, so kann er sich nicht selbstÀndig machen. Gute Isolierung ist Pflicht. icon_wink.gif
Falls Du den OEM-Widerstandswert wissen willst, bestell das Teil bei VW, mess es mit einem Multimeter durch und gib ihn zurĂŒck (vorher Fragen ob das möglich ist).
alexmulder
Post10-04-2008, 21:13    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
Hallo zusammen,
danke fĂŒr die Tipps und bitte nicht missversrehen ich will da nicht dran "rumfrickeln" nur er hat definitiv keinen Beifahrerairbag und das Golf SteuergerĂ€t ist auf 2 (Fahrer u. Beifahrerairbag) codiert und deshalb der Widerstand dazwischen. FĂŒr das umcodieren will VW 99,12 € haben und dann kann ich mir beinahe ein neues gönnen. Ich werde da am Samstag mal beigehen und dann berichten.
Alex
schraubernrw
Post01-05-2008, 16:48    Subject: Re-encoding Quote
alexmulder wrote:
Hello everyone,
Thank you for the tips, and please don't misunderstand me, I don't want to "mess around" with it. However, he definitely doesn't have a passenger airbag, and the Golf control unit is coded for 2 (driver and passenger airbag), and that's why the resistor is there. For the reprogramming, VW charges €99.12, and then I can almost get a new one. I will be there on Saturday and will report back afterward.
Greetings
Alex
Hello Alex,
I'm currently following your thread. I had my first experience with my Passat yesterday.
The price at Friendly is unbelievably high.
I would be happy to help you with the recoding if you have the access code and MWB.
I planned some research projects on my Passat on Saturday,
First log file, I have also checked through
Where are you at home!?
Markus
Passat Var TDI, Baujahr 01/99, 81KW, MKB AFN
alexmulder
Post02-05-2008, 20:58    Subject: Airbag control unit replaced, now error 00589. Translating...
[Translating...]
Hallo Markus,
muß zu meiner Schande gestehen das ich noch nicht dazu gekommen bin die WiderstĂ€nde zu verbauen. Ist fĂŒr das Pfingstwochenende geplant. Ich werde dann auch berichten. Das SteuergerĂ€t kann man nicht umcodieren, die einzige Möglichkeit ist die WiderstĂ€nde zwischen zu klemmen. Ich komme aus dem Raum Hannover.
Alex
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG, bis 8LYA078299 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error ZĂŒnder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 TDI: Fehler 65535 im Airbag-SteuergerÀt On-Board Diagnostics (OBD)
No new posts AFN SteuergerÀt gewechselt, Tuningchip austauschbar? On-Board Diagnostics (OBD)
No new posts Replace Airbag Control Unit: Guide & How-To On-Board Diagnostics (OBD)
No new posts Airbag Control Unit VW Golf 3 On-Board Diagnostics (OBD)
