Turbo Whistles for VW 1Z Models
Burli
Post16-03-2003, 9:50    Subject: Turbo Whistles for VW 1Z Models Quote
Okay, here's a dumb question that's been bothering me since I bought my Passat:
Is the turbo whistle really no longer audible?
After various problems with the charging regulation and VTG adjustment, the speedometer now indicates a top speed of approximately 185 km/h, which I believe is relatively slow.
Engine specifications:
1Z engine, 1.9 TDI, 90 horsepower, manufactured in August 1995.
Thank you and best regards.
Burli.
Translated on 27-09-2026, 5:27.
Post16-03-2003, 10:15    Subject: Turbo Piping for 1Z VW Models Quote
Burli wrote:
Is the turbo whistle really no longer audible??
Hi.
As far as I know, you can't usually hear a noticeable turbocharger whine in most TDIs. And if you do, it's usually only at low RPMs or when accelerating with the car stationary.
After various problems with the charging regulation and VTG adjustment, the speedometer now indicates a top speed of approximately 185 km/h, which, in my opinion, is relatively sluggish.
- The 1Z does not have a VTG supercharger.
- 185 kilometers per hour according to the speedometer, or is that the actual speed?
- Regarding the supposed sluggishness: the DZR test usually provides clarity icon_idea.gif.
Burli.
Translated on 27-09-2026, 5:29.
Burli
Post16-03-2003, 10:21    Subject: Turbo Whistles for VW 1Z Models Quote
Hello Ulf,
Actually, when I mentioned the VTG adjustment, I was referring to the adjustment of the bypass flaps.
'Nevertheless, thank you.'
Burli.
Translated on 27-09-2026, 5:31.
DocSnydor
Post16-03-2003, 10:47    Subject: Turbo Whistles for VW 1Z Models Quote
I'm not hearing any whistling from my turbo either. According to my LDA (likely referring to a data logger), the full boost pressure doesn't even kick in until around 2300 RPM (which is late, right?). But I'll worry about that later; first, I need to fix this rough idling.
Burli
Post17-03-2003, 9:15    Subject: Turbo Piping for 1Z VW Models Quote
[- as far as the supposed sluggishness is concerned: the DZR test usually provides clarity icon_idea.gif.
Um, where can I find this DZR test?
Unfortunately, I couldn't get any further using the search function icon_rolleyes.gif.
Translated on 27-09-2026, 5:32.
Michael II
Post17-03-2003, 9:17    Subject: Turbo Whistles for VW 1Z Models Quote
Left side, feature article, download Ulf's ventilation test new_cry.gif.
Tschüss
Michael II
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
