Kann man die Laufleistung eines Motors feststellen? | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Torfhausracer
Post11-05-2007, 19:06    Subject: Quote
Can you give me some advice on which workshops I could contact to find out the mileage of a car? Volkswagen dealerships are very reluctant to provide this information, and independent mechanics also don't really want to help when you ask.
Translated on 29-07-2026, 9:21.
mullemaus
Post11-05-2007, 21:51    Subject: Quote
I think you'll have to search for a long time; not many people icon_confused.gif do that.
Translated on 29-07-2026, 9:22.
vitkowal
Avatar-vitkowal
Post08-06-2008, 22:11    Subject: VAG.com: Check mileage easily! Quote
Hello!
Can't the actual mileage or corresponding data be read out using VAG-COM?
Best regards, mat.
Audi C4 103kW AEL EZ 11/96 290tkm
Audifahrer
Post09-06-2008, 6:52    Subject: VAG.com: How to Check Mileage Quote
vitkowal wrote:
Hello!
Regards, mat
Yes, from an EDC15.
For ECUs like the EDC16, programming is typically done either via an EEPROM programmer or, using more expensive equipment, through the OBD port.
What kind of vehicle are we talking about?
Translated on 29-07-2026, 9:23.
vitkowal
Avatar-vitkowal
Post09-06-2008, 16:19    Subject: Mileage Reading with VCDS: Which Cars? Quote
Hello!
Initially, I was just considering purchasing a VCDS (Vag-Com) device. The more useful applications this tool has, the more interested I am in it.
I would also use this before buying a used car. To list a few vehicle types that are of interest to me:
T4 5Zyl. TDI.
T5 TDI engines.
Audi C4, approximately 1996/1997.
Current A6 models.
LT2 4-cylinder TDI.
Crafter.
Do you need a different interface to determine the actual mileage? If so, perhaps it would be better to acquire one.
Best regards, mat.
Translated on 29-07-2026, 9:25.
Wiesel
Post09-06-2008, 17:05    Subject: Mileage Reading with VCDS: Which Cars? Quote
vitkowal wrote:
Do you need a different interface to determine the actual mileage - in that case, maybe it would be better to purchase one, or?
VAG-COM / VCDS is a diagnostic tool icon_exclaim.gif.
It's amusing that some ECUs offer the gimmick of displaying mileage.
But that's all there is to it.
"Firstly, many ECUs do not record the mileage, and secondly, people can..."
that are capable of manipulating the speedometers of current vehicles and also altering entries in the vehicle's electronic control units (ECUs).
Best regards, Micha.
Translated on 29-07-2026, 9:27.
vitkowal
Avatar-vitkowal
Post09-06-2008, 17:36    Subject: Mileage Reading with VCDS: Which Cars? Quote
Okay, understood.
I always thought that being read-only didn't necessarily mean it couldn't be manipulated.
Where can I find information about which vehicles VAG-COM can read the mileage from?
Best regards, mat.
Translated on 29-07-2026, 9:29.
Wiesel
Post10-06-2008, 10:00    Subject: Mileage Reading with VCDS: Which Cars? Quote
vitkowal wrote:
Where can I find information on which vehicles vag.com can read the mileage from?
I don't know of any openings.
Okay, let's assume that for most EDC15V engines (specifically, the 90 or 110 horsepower TDI models from the years 2000 to...
(referring to the year 2004). Everything else is a matter of luck, as it's usually not specified.
AFAIK, EDC16 is generally not supported.
Translated on 29-07-2026, 9:30.
Audifahrer
Post10-06-2008, 19:45    Subject: Mileage Reading with VCDS: Which Cars? Quote
Wiesel wrote:
vitkowal wrote:
Do you need a different interface to determine the actual mileage - in that case, perhaps it would be better to purchase one, or?
Best regards, Micha
That's not entirely accurate. With vehicles that have an EDC16 engine control unit, it's common to simply tamper with the speedometer because there are currently very few devices that can do so via the OBD (On-Board Diagnostics) port.
Opening an EDC16 and doing the whole process "manually" is quite time-consuming, so someone like "Hinterhoftachodreher" would probably prefer not to do it.
The vehicles listed are mostly quite old, so the condition is probably more important than the mileage.
The current A6 not only records the mileage in the instrument cluster (KI) and multi-function display (MSG), but also icon_wink.gif.
Translated on 29-07-2026, 9:33.
Wiesel
Post10-06-2008, 21:28    Subject: Mileage Reading with VCDS: Which Cars? Quote
Audifahrer wrote:
... so the "rear axle spin" is happy to do without it.
Your word in Otto's ear canal.
Now you can read the EEPROM of an EDC16 via OBDII; you can also extract the security access code via OBDII.
From MED9x/EDC16, you can verify the actual mileage of the vehicle that is stored within the EDC16/MED9 system.
You can change the odometer value in EDC16 engine control units... and do all of this via OBDII!
and the tool is quite widespread icon_confused.gif.
The current A6 not only records the mileage in the instrument cluster and message display, but also icon_wink.gif
Not only the A6 icon_mrgreen.gif.
Translated on 29-07-2026, 9:35.
Audifahrer
Post11-06-2008, 13:29    Subject: Quote
@Weasel:
The tool you mentioned is really expensive!
[edit_Weasel]I've toned down the statement a bit icon_wink.gif.[/edit]
Translated on 29-07-2026, 9:37.
Post11-06-2008, 13:47    Subject: Quote
I don't think we should be discussing alternative, cheaper, or better programs here, as manipulating the engine performance of a car doesn't belong in this forum and is also quite unethical.
Translated on 29-07-2026, 9:38.
Wiesel
Post11-06-2008, 14:16    Subject: Quote
Okay. Since I've said everything that needs to be said on the matter, I'm ending this here.
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Development of the 1.9 l TDI Engine Technical Articles
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts VW 1Z Engine ESP Tax Signal (VP37) On-Board Diagnostics (OBD)
No new posts Valve Guide Problems: How to Diagnose Diesel Engine Technology
No new posts How to diagnose alternator play Diesel Engine Technology
No new posts Loader Problems: How to Diagnose G2 TD Issues Diesel Engine Technology
