Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
03-12-2002, 9:46 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
Hey guys!!!
Okay, here's a question. Does anyone know how to retract the rear brake pistons on an A3 when you're installing new brake pads? The workshop wants to charge me 80 euros for something I've always done myself. And the Hazet retraction tool costs 150 euros. But I don't want to pay even more than the 50 euros for the pads.
Okay, here's the translation:
So please post quickly because I'm already  javascript:emoticon('}')
Best regards, Sevi!
Translated on 19-09-2026, 5:06.
Profile PM Garage |
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
04-12-2002, 16:39 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
Hi!
Okay, so I placed a suitable shim on the piston and, using a lever, I pushed the part back while applying constant pressure and rotational movements (I believe clockwise). The rotational movements are important for adjusting the handbrake!
Best regards, Christian.
Translated on 19-09-2026, 5:07.
04-12-2002, 17:29 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
Thanks for the tip, but I ended up taking it to the workshop yesterday. It cost me 214 euros, including the brake discs.
Next time, I'll try it the way you suggested.
"Cu."
This is a short form of the Spanish word "cuerpo," which means "body." It is often used in online communication to refer to a person's physical appearance.
Translated on 19-09-2026, 5:08.
Profile PM Garage |
Lanz Guest
04-02-2003, 8:56 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
I strongly advise against modifying the brakes yourself, if...
1. that the right tool is not available, or
2. lack of practical knowledge.
This brake system design is inherently a weak point in the car and extremely sensitive. When incompetence is added to the mix, the calipers are prone to failure. You'll notice this at the latest during the next vehicle inspection, when the workshop installs brand new calipers.
Best regards, Lanz.
Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
19-03-2003, 13:43 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
Hello!
Yes, yes, this brake caliper has already cost me a lot of time. I always borrow the original tool from a specialized company.  But be careful  :  Please do not experiment with pliers or other objects on the brake caliper. If the rubber boot is even slightly damaged, the brake caliper will eventually break. Also, some people have accidentally gotten dirt under the rubber boot when retracting it, which can also lead to significant damage to the brake caliper  .  So, it's better to invest a little and have a functioning brake with a warranty  . VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 19-09-2026, 5:10.
Profile PM Email Garage |
christians Profi-Schrauber
19-03-2003, 21:17 Subject: A3 Rear Brake Caliper Reset: How-To Guide |
"So, if a material of lower quality than that used in the Audi 100 is used (they look the same externally), you can definitely handle them roughly because they're not going to last long anyway. In my case, the handbrake mechanism regularly seizes up. I've had to replace 3 calipers in 5 years." Gruß Christian
Translated on 19-09-2026, 5:11.
