Front axle noises Golf III TDI 81KW
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
stefan krissel
Post04-04-2003, 11:52    Subject: Front axle noises Golf III TDI 81KW Quote
Hello everyone,
In the autumn, my Golf III TDI, with 200,000 km on the odometer, started making a loud noise on the front wheels. The squealing noise disappeared when I braked.
Okay, I've ordered the wheel bearings, and the shock absorbers were already due for replacement, plus the front axle was disassembled. New wheel bearings have been installed - incidentally, they were removed using a 16mm threaded rod, a very strong washer on the outside, and a U-shaped washer that had been properly ground/polished/cut, almost as large as the bearing itself, so the wheel bearing is now loose, and the rest can be easily removed. Pulling also.
So, also die Radlager sind drin, und die Stoßdämpfer auch, aber leider habe ich immer noch gelegentlich ein Geräusch (vor allem von der linken Seite), wenn das Auto ein paar Kilometer gelaufen ist, sowie auch eine Vibration, vor allem in Kurven nach rechts. Just got back from the TÜV - the steering has no play - and the noise is gone again, just like when it was making noise while braking.
Does anyone have anything else to add?
Could it be that the left brake cylinder is possibly being over-relieved, and the pad is 'floating'?
I noticed that the tread on the right side is a bit more worn.
Thank you.
kenny
Post04-04-2003, 13:14    Subject: Front axle noises Golf III TDI 81KW Translating...
[Translating...]Können auch die Gelenkwellen des Antriebs sein. Wenn die hinüber sind, ist das ne Kostspielige Angelegenheit. Meine verursachen auch Geräusche / Vibrationen. Ich werde mir mal neue Manschetten kaufen, die Gelenke auswaschen und neu einfetten, ich hoffe das bewahrt sie vor weiterem Verschleiß.
stefan krissel
Post04-04-2003, 14:55    Subject: Front axle noises Golf III TDI 81KW Translating...
[Translating...]Oh ja, vielen Dank, daran habe ich nicht gedacht, weil von wegen beim Bremsen, aber klar beim Bremsen nehme ich Last von den Wellen.
Ich versuchs mal, aber - muß man neue Manschetten nehmen, meine sind noch top, bräuchte nur neue Schellen.
Stefan
kenny
Post05-04-2003, 0:23    Subject: Front axle noises Golf III TDI 81KW Translating...
[Translating...]Ja bei mir sehen die aber ein bißchen verdächtig aus, sind ziemlich spröde geworden auf die jahre.... ich guck allerdings auch erstmal was so neue kosten. Ich dachte nur, das die evtl. nicht heile runter zu bekommen sind.
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Motor läuft nur mit 500 U/min, nimmt kein Gas an, 81KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 75PS GolfIII TD: Sporadische Startschwierigkeiten Diesel Engine Technology
No new posts Start problems 81KW (AHF) Diesel Engine Technology
No new posts Turboproblem??? AFN 81KW Diesel Engine Technology
No new posts Golf III TDI 81KW (AFN) On-Board Diagnostics (OBD)
