TT5 Programming for Audi A6
7thguest
Post09-01-2009, 21:34    Subject: TT5 Programming for Audi A6 Quote
Hello!
I am now the proud owner of a VAG-COM interface and, of course, I have already tried quite a few things with it.
As one of the first things I did with my TipTronic, I disabled the DSP. So far, that's worked well (and it feels better). Actually, I also wanted to activate the "new standard" setting, but it absolutely refuses to do so.
Could it be that there are control units that don't yet recognize this coding and therefore reject it, or am I missing something? Is it possible to "convince" it with a login?
currently:
Code:
Adresse 02: Getriebe
   Protokoll: KW1281
   Teilenummer: 4B0 927 156 CH
   Bauteil: AG5 01L 4.2l5V  RdW 1313
   Codierung: 00011
   Betriebsnr.: WSC 02325
...and I actually wanted to...
Code:
   Protokoll: KW1281
   Codierung: 00111
Okay, so it's two '0's followed by three '1's.
T-H-A-N-K-Y-O-U.
A6 4.2 Avant , VAG-COM/OBD2 Diagnose Profisystem KKL+CAN (USB)
Translated on 27-09-2026, 22:09.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post16-01-2009, 11:56    Subject: TT5 Programming for Audi A6 Quote
I can only speak from my own experience, and in that context, he only accepts the "new standard" when used in combination with DSP.
When DSP is inactive, it automatically shifts to first gear when the vehicle comes to a stop.
Translated on 27-09-2026, 22:11.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Immobilizer 1H0 953 257 B: Reprogramming & Replacement On-Board Diagnostics (OBD)
No new posts AHK Retrofit Programming: Guide & Tutorial On-Board Diagnostics (OBD)
No new posts Program Car Speedometer: Easy Guide Diesel Engine Technology
No new posts Program Daytime Running Lights? On-Board Diagnostics (OBD)
