2.5 V6 TDI: Schraube Keilriemenspanner abgerissen. | Posts 32+
Go to page: Previous  1, 2, 3
A6 Andreas
Post31-01-2009, 6:55    Subject: Quote
The picture of you reminds me of my air orgies.
I also had my filter sawed off back then.
Especially, after driving about 200 kilometers since the "crack" sound appeared, the tire was always completely flat.
The filter screen was always empty.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
 File size:  1.3 MB
 Viewed:  1551 times
Translated on 31-07-2026, 23:30.
A6 Andreas
Post31-01-2009, 7:10    Subject: Quote
One more, but the focus isn't very good.
I even used a vacuum pump to completely fill the diesel filter back then.
Then I clamped the fuel line to prevent any diesel from flowing back, and then I installed the pressure sensor.
The car looked like this after driving 100 km.
I repeated this procedure X times back then.
I almost doubted my own technical understanding back then.
The problem was fixed when I installed the male filter.
Those original filters made in China must have had some air leaks somewhere!
 File size:  588.04 KB
 Viewed:  965 times
 File size:  580.01 KB
 Viewed:  937 times
 Viewed:  906 times
Translated on 31-07-2026, 23:32.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post31-01-2009, 12:32    Subject: Quote
Yes, I know about those Chinese filters icon_evil.gif.
54 euros of junk.
The filter from Teileklaus is significantly better.
Nevertheless, the hose connected to the supply line is the second major hazard.
The silicone tubes are not fitting tightly enough on the filter and are being pinched by the clamp.
It's really annoying about this filter issue icon_confused.gif.
Translated on 31-07-2026, 23:33.
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screw broken off in the turbocharger Diesel Engine Technology
No new posts High-pressure pump screw sheared off, need help Diesel Engine Technology
No new posts Missing screw from brake disc assembly (torn off) - is th... Transmission, Chassis, Body & Interior
No new posts Broken Engine Mount: Causes & Repair Diesel Engine Technology
