CV joint problems on a Passat 35i
Cheffe
Post25-05-2002, 16:34    Subject: CV joint problems on a Passat 35i Quote
I have a Passat 35i, manufactured in 1994.
"I've been having problems with my central heating system for a while now." When you close and lock the driver's door, all the doors should lock, but the indicator light that shows the alarm system (DWA) is active does not blink. (However, the alarm system is active; I have tested it.)
If you try to unlock the door, only the driver's door will open; all other doors will remain locked, and the immobilizer (DWA) will not be deactivated. If you try to start the engine, the immobilizer will activate.
I have already removed the door handle assembly and the lock cylinder and inspected them for faults (I suspect the microswitch).
The strange thing is that the error doesn't always occur, but only sporadically, and only on the driver's side door; everything works perfectly fine from the passenger's side door.
Has anyone had similar experiences or have any advice?
*Mario*
D. Kurz
Post25-05-2002, 17:58    Subject: CV joint problems on a Passat 35i Quote
Hello boss!
You're not entirely wrong to suspect microswitches. However, it's usually not the switches themselves that are the problem, but rather the mechanism within the lock that actuates the central locking switches, which wears down over time. So, if you turn the key in the lock a little too far upwards, it should work.
'I occasionally experience the same problem with my 35i, but a new lock is simply too expensive for me.'
Dominique.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 1Z Engine Problems: Troubleshooting Guide Diesel Engine Technology
No new posts Passat 3B - Issues with Comfort Control Unit / Instrument... On-Board Diagnostics (OBD)
No new posts ZF 5HP19 automatic transmission problems in the VW Passat... Transmission, Chassis, Body & Interior
No new posts Passat 3B MBK: AFN Engine - Black Smoke Issues On-Board Diagnostics (OBD)
