BLS 3C Loader: Top or Bottom?
vwSchrauber
Post07-12-2009, 15:19    Subject: BLS 3C Loader: Top or Bottom? Quote
How should the turbocharger be removed from a Passat 3C with engine code BLS?
I unscrewed it, but I couldn't get it out. I couldn't get it out from the top, even after removing the intake manifold, and I couldn't get it out from the bottom, because the right driveshaft is in the way.
Since it's already defective, I've now removed the pressure sensor, and I took it out through the center tunnel (where the DPF also exits, if it's still there icon_twisted.gif).
Since I don't want to/can't/am not allowed to play this game with the new loader because it's under warranty, and the VTG linkage shouldn't be adjusted, I would like you to explain to me where this thing should come out.
"Thank you."
John.
Translated on 16-09-2026, 19:25.
mullemaus
Post07-12-2009, 15:29    Subject: BLS 3C Loader: Top or Bottom? Quote
Go down. Remove the DPF, remove the connecting pipe to the exhaust gas recirculation cooler, remove the lower support, etc., etc. icon_wink.gif
Translated on 16-09-2026, 19:26.
vwSchrauber
Post07-12-2009, 16:05    Subject: BLS 3C Loader: Top or Bottom? Quote
Remove DPF
There was nobody inside icon_cool.gif.
Remove the connecting pipe to the exhaust gas recirculation cooler
I have.
Support from below
It's also outside...
Does the heat shield (aluminum plate) in the center tunnel now need to be removed, or will it work without it? I think I remember that it had to be removed when the DPF was replaced before *scratching head*.
Translated on 16-09-2026, 19:27.
chli1976
Post07-12-2009, 16:17    Subject: BLS 3C Loader: Top or Bottom? Quote
Doesn't the generator support need to be lowered?
VCDS
Translated on 16-09-2026, 19:28.
mullemaus
Post07-12-2009, 16:46    Subject: BLS 3C Loader: Top or Bottom? Quote
Is it not necessary to lower the aggregate carrier icon_wink.gif?
We certainly expect some level of visual acuity. }
vwSchrauber
Post09-12-2009, 9:02    Subject: BLS 3C Loader: Top or Bottom? Quote
Doesn't one have to lower the generator carrier?
We do, of course, expect some visual work to be done
Oops...
Then it's better to remove the heat shield, or disassemble the charger icon_rolleyes.gif.
Translated on 16-09-2026, 19:29.
vwSchrauber
Post10-12-2009, 11:03    Subject: BLS 3C Loader: Top or Bottom? Quote
Okay, heat shield removed, power steering shroud removed, front axle lowered by 1cm, shift cables moved aside, and then it went in with carefully applied force icon_lol.gif.
Are there any torque specifications for the 6 screws on the front axle?
Post10-12-2009, 12:18    Subject: BLS 3C Loader: Top or Bottom? Quote
Generator carriers:
M 12 x 110, 70 Nm + 90°, Use new screw(s).
M12 x 100, Grade 01, 70 Nm torque, Use new screw(s).
M12 x 100, Grade 02, 180°
M 12 x 90, torque setting 01, 70 Nm, use new screw(s).
M 12 x 90, Level 02, 180°.
Translated on 16-09-2026, 19:30.
vwSchrauber
Post10-12-2009, 12:31    Subject: BLS 3C Loader: Top or Bottom? Quote
Thank you!
Translated on 16-09-2026, 19:31.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts VW Golf ALH Turbo: Top or Bottom Removal? Diesel Engine Technology
No new posts Underbody Protection for VW Golf 5 Transmission, Chassis, Body & Interior
No new posts Correction (oil change below) Diesel Engine Technology
No new posts Problem with AFN: Very little performance when running in... Diesel Engine Technology
