asillisa Guest
20-12-2009, 10:01 Subject: |
What will it cost?
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
20-12-2009, 19:07 Subject: |
Please provide the text you would like me to translate from German to English.
Profile PM WWW Garage |
asillisa Guest
22-12-2009, 9:55 Subject: |
It was definitely the engine control unit (ECU). My tuner received the old control unit yesterday to try and fix the problem, and I'm supposed to cover the costs, which he will present to me.
22-12-2009, 10:01 Subject: |
Okay, please provide the text you would like me to translate from German to English.
asillisa wrote: | | It was definitely from the engine control unit; my tuner was given the old control unit yesterday to fix the problem, and my costs are still being charged to him!! |
Further up, but like this:
asillisa wrote: | | ...since Thursday, the car has been at VW. They initially said the control unit was defective and ordered a new one. They installed the new control unit, but the same error persists... |
Are you sure the error is gone? MfG. Michael
Profile PM Garage |
asillisa Guest
23-12-2009, 9:40 Subject: |
I think it's possible because my own control unit, which had a loose connection, might have been working at that moment, and they didn't know that the control unit had a problem. They assumed the new control unit worked immediately, just like my own did at that time.
Octavia_4x4 Schrauber
23-12-2009, 21:30 Subject: |
asillisa wrote: | Do other engine control units (ECUs) also fit in the car, such as those from the 110 hp engine or from other 90 hp engines, etc.?
if so, what should be considered? |
"It's not possible. The 110 hp version has a different engine map, different injectors, and a different opening pressure." Furthermore, various other parts are available in the area of the crankshaft/bearings/clutch.
In principle, it is possible to convert an ALH engine to run on ASV fuel, as the cylinder head, fuel injection pump, and turbocharger are the same, but simply swapping the engine control unit (ECU) is not a straightforward process.
"While this might not be relevant to you right now, I'm adding this as a supplement."
asillisa Guest
23-12-2009, 21:47 Subject: |
What all needs to be done to convert an ALH engine to an ASV engine?
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
24-12-2009, 13:15 Subject: |
The MSTG hardware may already be compatible, but you need to find the correct dataset.
bring it to the STG... and that means taking out the soldering iron again, and knowing what you're doing  . Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
asillisa Guest
26-12-2009, 16:00 Subject: |
and what kind of horsepower can you potentially squeeze out of the engine?
26-12-2009, 16:49 Subject: |
But isn't your car already tuned?
No, I won't tune your car. Why are you asking after I supposedly fixed the problem?
I'm just not understanding this somehow...
asillisa Guest
26-12-2009, 17:19 Subject: |
With the new engine control unit, it now has 90 horsepower again, and I gave the old one back to my tuner.
'I was just curious to know what the difference is between the 90 hp and the 110 hp TDI engines. Also, I don't quite understand who asked you if you could tune my car?'
26-12-2009, 17:37 Subject: |
Please use the search function; this question has been asked 100 times already. There are different 90 horsepower engines and different 110 horsepower engines!
