Golf 5 2.0 TDI 4Motion: Noise from Rear Right
servusssss
Post21-01-2010, 18:28    Subject: Golf 5 2.0 TDI 4Motion: Noise from Rear Right Quote
Hello everyone,
Does anyone else experience this problem?
Regarding the car: It's a Volkswagen Golf 5 4Motion with a 2.0 TDI engine (Autoscan results at the end).
Problem: I'm experiencing a knocking/scraping sound coming from the rear right wheel that only occurs at low speeds (and is very loud).
The noise is no longer audible when the wheel is turned while it's on the jack.
Already excluded:
- No stones between brake pad/disc/caliper bracket.
- Brake pad does not crumble or detach.
- The handbrake releases smoothly and completely.
The only thing I could determine is that the right drive shaft has approximately 1 mm of play, while the left one does not. (The vehicle is parked on a level surface).
My guess is that there might be a problem with a joint or the wheel bearing.
Is that normal?
If so, how can I quickly check which one is broken?
If not, what else can/should I look at or check?
Sure, here's the translation:
"Best regards, Christian."
Code:
Fahrzeug-Ident.-Nr.: WVWZZZ1KZ6W043xxx Kilometerstand: 51220km
00-Lenkwinkelsensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Bremsen -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
18-Standheizung -- Status: Fehler 0010
19-CAN-Gateway -- Status: OK 0000
22-Allrad -- Status: OK 0000
25-Wegfahrsperre -- Status: OK 0000
42-Türelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: OK 0000
52-Türelektr. Beifahr. -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Türelektr. hi. li. -- Status: OK 0000
69-Anhänger -- Status: OK 0000
72-Türelektr. hi. re. -- Status: OK 0000
Adresse 01: Motor        Labeldatei: RKS\03G-906-016-BKD.lbl
   Teilenummer SW: 03G 906 016 AQ    HW: 028 101 184 8
   Bauteil: R4 2,0L EDC G000SG  7000
   Revision: 12345678    Seriennummer: VWZ7Z0E2487915
   Codierung: 0000172
   Betriebsnr.: WSC 01279 785 00200
Kein(e) Fehler gefunden.
Readiness: 0 0 0 0 0
Adresse 03: Bremsen        Labeldatei: RKS\1K0-907-379-MK60-A.lbl
   Teilenummer SW: 1K0 907 379 R    HW: 1K0 907 379 R
   Bauteil: ESP 4MOTION MK60    0102
   Revision: 00T12001
   Codierung: 0023170
Adresse 08: Klima/Heizung        Labeldatei: RKS\1K0-907-044.lbl
   Teilenummer: 1K0 907 044 BC
   Bauteil: ClimatronicPQ35 066 0606
Adresse 09: Bordnetz        Labeldatei: RKS\3C0-937-049-23-H.lbl
   Teilenummer SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Bauteil: Bordnetz-SG     H37 1002
   Revision: 00H37000    Seriennummer: 00000002119917
   Codierung: 038B8F2701041800001400001400000000097F075C
   Teilenummer: 1K1 955 119 C
   Bauteil: Wischer VW350  013  0402
   Codierung: 00065493
Adresse 15: Airbag        Labeldatei: RKS\1K0-909-605.lbl
   Teilenummer SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Bauteil: 2E AIRBAG VW8   015 2100
   Revision: 03015000    Seriennummer: 0038ED0KCCJF
   Codierung: 0012869
   Betriebsnr.: WSC 01269 785 00200
Adresse 16: Lenkrad        Labeldatei: RKS\1K0-953-549-MY8.lbl
   Teilenummer SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Bauteil: J0527           634 0070
   Codierung: 0002022
   Teilenummer: XXXXXXXXXXX
   Bauteil: E0221           007 0050
Adresse 17: Kombiinstrument        Labeldatei: RKS\1K0-920-xxx-17.lbl
   Teilenummer: 1K0 920 872 B
   Bauteil: KOMBIINSTRUMENT VDD 1212
   Codierung: 0007103
   Betriebsnr.: WSC 00805 219 58059
Adresse 18: Standheizung        Labeldatei: RKS\1K0-815-007.lbl
   Teilenummer: 1K0 815 007 AP
   Bauteil: Standheizer     020 3602
   Revision: 00020000    Seriennummer: 09011559000000
   Codierung: 0001112
1 Fehler gefunden:
01406 - keine Flammenbildung
            000 -  -  - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100000
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 16
                    Kilometerstand: 50422 km
                    Zeitangabe: 0
                    Datum: 2000.00.00
                    Zeit: 15:00:19
                        Start
                    Temperatur: 71.0°C
                    Temperatur: 67.0°C
Adresse 19: CAN-Gateway        Labeldatei: RKS\1K0-907-530.lbl
   Teilenummer SW: 1K0 907 530 F    HW: 1K0 907 951
   Bauteil: Gateway         H10 0120
   Revision:   H10       Seriennummer: 2800105819013E
   Codierung: FD3F5340070002
Adresse 22: Allrad        Labeldatei: RKS\1K0-907-554.lbl
   Teilenummer: 1K0 907 554 B
   Bauteil: HALDEX 4Motion      0107
   Codierung: 0000001
Adresse 25: Wegfahrsperre        Labeldatei: RKS\1K0-920-xxx-25.lbl
   Bauteil: IMMO            VDD 1212
Adresse 42: Türelektr. Fahrer        Labeldatei: RKS\1K0-959-701-MIN2.lbl
   Teilenummer: 1K0 959 701 K
   Bauteil: Tuer-SG         024 2369
   Codierung: 0000180
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x.lbl
   Teilenummer: 1K1 909 144 J
   Bauteil: EPS_ZFLS Kl.5   D04 1606
Adresse 46: Komfortsystem        Labeldatei: RKS\1K0-959-433-MAX.clb
   Teilenummer SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Bauteil: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Seriennummer: 00000000000000
   Codierung: 809002085103087F2D04840560084F01E0A440
   Betriebsnr.: WSC 01287 785 00200
   Bauteil:   Sounder n.mounted
   Bauteil:       NGS n.mounted
   Bauteil:      IRUE n.mounted
Adresse 52: Türelektr. Beifahr.        Labeldatei: RKS\1K0-959-702-MIN2.lbl
   Teilenummer: 1K0 959 702 K
   Codierung: 0000180
Adresse 55: Leuchtweitenreg.        Labeldatei: RKS\1T0-907-357.lbl
   Teilenummer: 1T0 907 357
   Bauteil: Dynamische LWR      0003
   Codierung: 0000004
Adresse 56: Radio        Labeldatei: RKS\1K0-035-1xx-56.lbl
   Teilenummer: 1K0 035 186 P
   Bauteil: Radio BVX       017 0023
   Codierung: 0040400
Adresse 62: Türelektr. hi. li.        Labeldatei: RKS\1K0-959-703-GEN2.lbl
   Teilenummer: 1K0 959 703 F
   Bauteil: Tuer-SG         021 2429
   Codierung: 0000144
Adresse 69: Anhänger        Labeldatei: RKS\8P0-907-383.lbl
   Teilenummer SW: 8P0 907 383     HW: 8P0 907 383
   Bauteil: ANHAENGERELEKTR H01 0010
   Codierung: 0000001
Adresse 72: Türelektr. hi. re.        Labeldatei: RKS\1K0-959-704-GEN2.lbl
   Teilenummer: 1K0 959 704 F
   Codierung: 0000144
Ende   --------------------------------------------------------------------
Translated on 04-08-2026, 1:37.
Post21-01-2010, 19:11    Subject: Golf 5 2.0 TDI 4Motion: Noise from Rear Right Quote
Are you ABSOLUTELY SURE that there is no NAIL or anything else embedded in the tire tread? Also, have you manually rotated the tire quickly and listened for any unusual noises?
I consider 1mm of clearance to be normal!
Translated on 04-08-2026, 1:39.
servusssss
Post21-01-2010, 19:14    Subject: Golf 5 2.0 TDI 4Motion: Noise from Rear Right Quote
No, I haven't looked at the tire yet.
I didn't think about that because I was driving on snow!
"Sg" means "singular". It is used to indicate that a noun or pronoun is in the singular form. For example, the sentence "The cat is black" uses the singular noun "cat". The sentence "He is tall" uses the singular pronoun "he".
Translated on 04-08-2026, 1:40.
Post21-01-2010, 20:37    Subject: Golf 5 2.0 TDI 4Motion Noise - Rear Right Quote
servusssss wrote:
The only thing I could determine is that the right drive shaft has approximately 1 mm of play, while the left one does not? (The vehicle is on a level surface).
Is that normal?
Do you mean the drive shaft or the wheel when you say "drive axle"?
Drive shaft: Play on the right / left side is normal. The play around the axis of rotation, in my opinion, is borderline. Please describe more precisely at which point you are measuring the 1mm (whether it's on the approximately 3cm thick shaft or on the approximately 10cm thick joint, as that makes a big difference icon_wink.gif).
Play in the wheel: If there is equal play on the front/back and top/bottom, then the wheel bearing is likely defective. If the play is different, then check the individual joints.
Does the noise always occur at low speeds (except in the unloaded case when the vehicle is on a jack)?
Can you hear it even at walking speed, and is it possible to see something by running alongside it?
Since you mentioned snow: If the noise only occurs sporadically, could it be due to a buildup of snow in the wheel well?
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 04-08-2026, 1:42.
servusssss
Post22-01-2010, 8:38    Subject: Golf 5 2.0 TDI 4Motion: Noise from Rear Right Quote
The wheel bearing has no play in any direction.
The play is located at the outer joint of the drive shaft/half-shaft.
I've scraped all the snow/mud etc. out of the wheel wells.
The noise is audible even at walking speed. I didn't see anything unusual when lifting it, and it doesn't seem to be getting hot or anything (at least not noticeably).
The faster you drive, the quieter it gets, which is kind of strange.
Okay, I'm going to explain everything now, and then...
"Dear Christian,"
Translated on 04-08-2026, 1:45.
Post22-01-2010, 16:45    Subject: Golf 5 2.0 TDI 4Motion: Noise from Rear Right Quote
It probably sounds like a driveshaft issue. If possible, have someone else put the car on jack stands while you're inside. Have that person give it gas and accelerate in first or second gear, while you move the steering wheel around! It might only happen under load.
Translated on 04-08-2026, 1:46.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Strange Noise/Vibration Front Right Diesel Engine Technology
No new posts Changing the headlight alignment from right-hand to left-... Transmission, Chassis, Body & Interior
No new posts 4Motion: How to Modify All-Wheel Drive Transmission, Chassis, Body & Interior
No new posts Golf 4Motion Turbo: Diagnose & Probleme On-Board Diagnostics (OBD)
