Einspritzung stilllegen nach Oelwechsel | Posts 16+
Go to page: Previous  1, 2
scroll tdi
Karma: +5 / -3   Thank you, like it!
Post26-01-2010, 12:49    Subject: Quote
a dancer wrote:
I no longer change the oil myself on my ATD vehicle, due to an auxiliary filter. Whether that's a good thing remains to be seen.
However, I would never pour ice-cold oil into a hot engine, for the same reason as with coolant.
I highly doubt whether using a bypass filter is a good idea for the ATD system.
Since a hydrocracked oil is being used here, the high pressures are essentially reverting the hydrocracked oil back into a conventional oil.
Similarly, the base number of the oil should be checked to ensure it doesn't become too acidic.
Similarly, what about the up to 7% biodiesel in gasoline? Does that mean you need to regularly check your oil for fuel dilution?
Furthermore, if you change the oil with a hot engine and then add oil that is not suitable for normal operating temperatures, you may have drained the old oil too early.
Warm up the engine normally. Wait 10 minutes until all the oil has drained into the pan. Open the oil filter and drain plug.
Translated on 20-07-2026, 18:12.
mserge
Post26-01-2010, 12:55    Subject: Quote
vwSchrauber wrote:
I find it alarming that even many cheap, fully synthetic 15W-40 oils meet the 50500 standard icon_rolleyes.gif
"The so-called 'basic' oils aren't actually that bad, and they are often perfectly adequate for many engines if used correctly."
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 20-07-2026, 18:14.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post28-01-2010, 13:44    Subject: Quote
mserge wrote:
vwSchrauber wrote:
However, I find it alarming that many cheap, fully synthetic 15W-40 oils also meet the 50500 standard icon_rolleyes.gif
The "simple" oils aren't actually that bad, and they are often sufficient for many engines if used correctly...
Then put some "simple" 15W-40 oil in the freezer at -15°C. I doubt you really want to start your car in winter with that icon_wink.gif.
If the 15W-40 oil were completely free of additives, it could at least be used in classic cars with bimetallic bearings.
"Micha"
Translated on 20-07-2026, 18:15.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ganz kurz: Oelwechsel ASV Diesel Engine Technology
No new posts VW Golf 6 GTD: Disable Sound Actuator Electrical Systems, Vehicle Electronics, Multimedia
No new posts LPG injection Diesel Engine Technology
No new posts Ford C-Max: 3-Month Parking - Questions & Answers Diesel Engine Technology
