VCDS & Y22DTR: Troubleshooting & Repair
Post25-01-2010, 10:14    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
Hi.
Can I access error codes for the great VP44 injection pump (Y22DTR engine) using VCDS?
I'm asking in advance so that I can avoid making the trip if it's not necessary.
Okay, here's the translation:
Thank you.
Translated on 23-10-2026, 20:00.
Post25-01-2010, 10:25    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
What is the car's model year?
Post25-01-2010, 10:26    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
It's a Zafira A from 2003.
To my knowledge, he is "on the borderline" with that.
Translated on 23-10-2026, 20:01.
Post25-01-2010, 11:05    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
dieselmartin wrote:
To my knowledge, he is "at the limit" with that.
Right, don't you know the exact date?
mullemaus
Post25-01-2010, 11:28    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
Gasoline cars from approximately 2000 and diesel cars from 2003. However, without a test, it will be difficult to make a statement. icon_wink.gif Try it once and post the result. icon_biggrin.gif
Post25-01-2010, 11:46    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
You're right, I mixed that up with the OBD-AU requirement. That came into effect for diesel vehicles on October 1, 2005.
Translated on 23-10-2026, 20:02.
Stefan_2.0TDI
Post25-01-2010, 13:49    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
It's no coincidence that the new on-board diagnostics (OBD) system is only required for vehicles first registered on or after April 1, 2006.
Considering that the 2003 Zafira is still the older model (Zafira A) from 1999, I highly doubt that it's already OBDII compatible.
Translated on 23-10-2026, 20:03.
chriskross
Post01-02-2010, 19:00    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
The Zafira A model from 2005 definitely has an OBD connector, and it's located under the cover near the handbrake.
A6 AFB
A6 BRE DPF
Translated on 23-10-2026, 20:04.
Stefan_2.0TDI
Post01-02-2010, 19:13    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
It does have an OBD socket, but it is not compatible with the OBDII standard.
Post03-02-2010, 12:12    Subject: VCDS & Y22DTR: Troubleshooting & Repair Quote
Hi.
I got through.
But I couldn't produce more than a handful of knives, and possibly some errors (though there weren't any).
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
