Fachgerechtes Anziehen der KW Zentralschraube beim AKE ? | Posts 16+
Go to page: Previous  1, 2
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post08-01-2010, 14:09    Subject: Quote
Yes, I can't say which part is more durable, but at least one of the parts is located much further out on the interlocking, so the force is also reduced.
You can lift a beetle onto a 6mm screw icon_cool.gif Clear Shear Force / Tensile Force: just for getting to know each other icon_biggrin.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
christians
Post08-01-2010, 16:13    Subject: Quote
The tip has a diameter of 8 or 10mm. If it's 8mm, that's 50mm². The estimated radius at the KW (presumably a connection point) is 100mm, which at 450NM results in 4500 N. Therefore, the shear stress is 4500N/50mm² = 90 N/mm².
Gruß Christian
Post08-01-2010, 23:46    Subject: Quote
Okay, I trust you/the Dorn. icon_lol.gif If only the X3 hadn't been there. That's why I know exactly how 200Nm + 180° "feel". I've replaced the wheel bearings, and the central screw of the drive shaft gets exactly that amount. 200Nm is no problem, the first 90° also went smoothly, but from around 120° it became "good" and difficult, and from 150° I was firmly convinced that something big was about to happen. icon_lol.gif
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post08-01-2010, 23:59    Subject: Quote
And, how about the 200 NM+ 180 degrees?
1.5 m pipe and 80 KG or less?
And that's what you were trying to achieve with the loose engine icon_eek.gif
Post09-01-2010, 0:12    Subject: Quote
2 m pipe, and well sealed. In KG, no idea icon_question.gif Subjective: A lot. icon_twisted.gif
Karma: +1344 / -0   Thank you, like it!
Post09-01-2010, 20:06    Subject: Quote
Hello Michael,
Although I don't know the AKE, couldn't you just screw a fixture onto the KW timing belt wheel? That's what I do with the 1Z. I created the housing from steel plate, with an opening for the central screw and two holes for screwing in the threaded holes for the pulley.
Then you have the moment at the lever arm of the key and the moment at the fulcrum in the same plane.
Post09-01-2010, 20:20    Subject: Quote
Herbert wrote:
Hello Michael,
Good idea. Would also work without problems with the AKE, because the vibration dampener on the timing belt pulley is fixed with screws.
Post05-02-2010, 13:06    Subject: Quote
Okay, here is the final report:
Came with the thorn, but the thorn represents more of a "disposable product" in this usage. It's already a bit crooked. icon_twisted.gif I think he might be able to fix it again, but he'll definitely break it on the third time. icon_wink.gif
A6 Andreas
Post16-02-2010, 22:14    Subject: Quote
When I had it on, I also used a thorn.
Worked wonderfully!
I also had strong concerns about pruning.
The screw must be completely screwed in and then evenly, without jerking, tightened to 180 degrees, of course, according to the 200Nm specification.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Audi 80: Replace Crankshaft Position Sensor? Diesel Engine Technology
No new posts Torque Wrench 27Nm: Troubleshooting Noise Issues Transmission, Chassis, Body & Interior
No new posts VP37 Cable Screw: Alternative to Hex Head Screw Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
