Resetting the airbag control unit after deployment
voss
Post11-06-2003, 20:48    Subject: Resetting the airbag control unit after deployment Quote
Hello.
I have a question:
Can a VAG-COM device be used to reset an airbag control unit (module) after it has been triggered?
(of course, after replacing everything that needs to be replaced, such as the airbag and sensors...)
What does the error message in the STG say?
How do you reset it?
Thank you.
Voss.
Post12-06-2003, 7:41    Subject: Resetting the airbag control unit after deployment Quote
You cannot reset an airbag control unit (STG) using VAG COM or other diagnostic tools. These safety-critical components should be designed in such a way that it is impossible to use a second one.
Stefan
Post12-06-2003, 10:12    Subject: Resetting the airbag control unit after deployment Quote
That's not a problem with the right tools.
You can feel free to send me your control unit.
I'll pay you back for it later.
You'll receive the address and other details via private message.
Post12-06-2003, 11:04    Subject: Resetting the airbag control unit after deployment Quote
Hi Stefan,
Stefan wrote:
This is not a problem with the right tools.
You will receive the address, etc. via private message.
Can you ensure that the ignition system is functioning 100%? In our testing labs, we have observed that approximately 25% of airbag control units (ECUs) fail to deploy (or deploy incorrectly) after being triggered and reset.
@all
Stop these dangerous modifications to safety components. Anyone who manipulates these components must be aware that they will be held responsible for the consequences in case of failure (e.g., liability for damages in case of injuries). With the new STG, this responsibility rests solely with the manufacturer!
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LL Service: What event can trigger it? Diesel Engine Technology
No new posts Reset Service Indicator A3 MJ 97 Diesel Engine Technology
No new posts Reset Learning Rates: Null Set Correction On-Board Diagnostics (OBD)
No new posts Service zurücksetzen Audi A3 8p On-Board Diagnostics (OBD)
