Gearbox Shortening: Smooth Shifting at 37k Miles
Post05-03-2009, 1:25    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Hi.
(Image)
This is supposed to be an original VW short shifter.
Apparently, everyone has the 1K0 711 046 N part installed - and that definitely can't be right?!?!?
Can someone confirm the part number 8J0 711 046 B?
Translated on 27-09-2026, 5:33.
Post07-03-2009, 1:13    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
So, 100 people have read it, and nobody cares icon_smile.gif.
That's enough reason for me to order it, because then I'll be one of the 100 people who have it (that was a joke). But I will order it.
Then there will also be an installation guide.
Translated on 27-09-2026, 5:34.
vc
Post08-03-2009, 0:39    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
The short shift linkage 8J0 711 046 B is included with the S3 models from the year 2003 onwards (?), and costs €23.50. I ordered it today, and I'm hoping it will give my A3 8P with a BKD engine the same short shift feel as the S3. According to information from another forum, you need to replace the cable clamp until the year 2005 (the question mark is from the original post) because the fixing pin on the shift linkage lever has a 10 mm pin for attaching the shift cable, along with the corresponding cable clamp. However, the new lever has an 8.5 mm pin.
Translated on 27-09-2026, 5:35.
Post08-03-2009, 8:29    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Most likely, the hole for attaching the cable linkage is simply located closer to the axis of rotation.
A drill or a welding machine icon_cool.gif might have also been sufficient.
If you have a picture showing the lever (I'm not sure which specific configuration the picture depicts), you can determine the same drilling position by transferring the proportions, for example, of the mounting nut.
Translated on 27-09-2026, 5:37.
Post08-03-2009, 21:54    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
vc
As far as I know, the locking mechanism is included when you buy the lever.
The day after tomorrow, I will know more icon_wink.gif.
Then there are also photos of the standard, long, and short versions (which is probably also used in the GTI Edition30).
Translated on 27-09-2026, 5:38.
Post10-03-2009, 19:29    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Okay, please provide the text you would like me to translate from German to English.
The part has arrived.
http://tequila.homeip.net/Passat/S3_Schalthebel/
Installation depending on the weather.
Post10-03-2009, 21:42    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
I'm looking forward to reading your reports icon_cool.gif.
Heheh, the caliper is from ALDI or LIDL icon_lol.gif. I have one too!
Translated on 27-09-2026, 5:39.
Post10-03-2009, 22:26    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
People who spend so much money upgrading a car like an expensive Passat probably can't afford anything else.
Okay, otherwise, I'm not too picky about the prices when it comes to tools.
But the display is ideal for photos.
Post14-03-2009, 22:27    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
The part is installed and it drives quite nicely. It's not extremely short, but it feels a bit more responsive.
I can recommend it.
The most important change was probably that I re-lubricated the sliding joint and the selector/shift mechanism, which connects to the transmission on a single shaft (where the MQ 350 is located).
After only 37,000 kilometers, the old gear stick here shows clear signs of wear and tear.
Generally, the old lever is covered with a layer of fine, but well-adhering dirt from the front. This dirt also accumulates wonderfully in the grease of the sliding piece. Smooth shifting is quickly a thing of the past.
Translated on 27-09-2026, 5:40.
Post21-01-2011, 16:21    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
To the 1.9 TDI section, those of you who are messing around with an MQ250.
Your solution is called 8J0 711 046 A.
Translated on 27-09-2026, 5:42.
Post25-01-2011, 23:14    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Buy it.
 File size:  76.77 KB
 Viewed:  7492 times
haithamina
Post26-01-2011, 12:29    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Does that also apply to a 2003 EEN?
You're welcome, haithamina.
Post26-01-2011, 12:49    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
Sorry.
3Bx "Audis" do not have a seat adjustment function icon_arrow.gif and therefore do not fit.
Translated on 27-09-2026, 5:43.
Post29-01-2011, 18:32    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
is now also in the golf game, and I say:
Buy, buy, buy.
Although I already have the 12% reduction in the 3C, I am very excited about the 1K with 12% less forearm luxation icon_wink.gif.
Translated on 27-09-2026, 5:44.
Octavia_4x4
Post04-02-2011, 20:28    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
"Hey, since you're writing about cleaning and greasing things, I'm also having some issues with the shifting on my car, which has 240,000 km, a 6-speed transmission, and 4Motion. Would the S3 part also fit in my case?"
Shorter shift travel wouldn't actually be that bad.
Did you have to readjust the settings after that?
EDIT: If I remember correctly, the gearbox code should be ESW.
EDIT 2: If I understand correctly, and I remove that diverter lever from my machine, nothing will happen, right? Just the nut that holds it onto the shift shaft in the gearbox? Or will it fall into the gearbox? Because if that happens, I could at least clean and lubricate it from behind.
Translated on 27-09-2026, 5:45.
Post04-02-2011, 22:07    Subject: Gearbox Shortening: Smooth Shifting at 37k Miles Quote
dieselmartin wrote:
Does it fit?:
However, it apparently doesn't fit on all M350 models: Regarding the shift lever, the 9N and 6L models have the forward-reverse lever and the up-down block one after the other, instead of facing each other.
Even with the standard version, the forward-reverse lever is so short that the cable head, when a gear is engaged, almost touches the up-down control lever.
Therefore, implementing a SWV (Steering Wheel Vibration) would require a complete redesign of the steering column actuation system...
 File size:  107.46 KB
 Viewed:  14125 times
 File size:  76.77 KB
 Viewed:  5692 times
Translated on 27-09-2026, 5:46.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional Smoke & Burning Smell: What to Do? Diesel Engine Technology
No new posts Golf TDI Manual: Specs, Review & More Diesel Engine Technology
No new posts NSW: Switching Off! On-Board Diagnostics (OBD)
No new posts Auxiliary heater - activate ventilation EXTRA Transmission, Chassis, Body & Interior
