Leon door lock
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post07-03-2011, 23:50    Subject: Leon door lock Quote
Hi, I noticed something while working on my Leon. The small LED in the driver's door isn't blinking anymore when I lock the car remotely. Also, the anti-theft alarm system seems to be out of order. Unfortunately, I couldn't get any further with VCDS. Could the driver's lock be the problem?
reflexsilber met.
Post08-03-2011, 0:02    Subject: Leon door lock Quote
Please check all locks/microswitches for plausibility using the Multi-Wire Balancing (MWB) method.
RedR32
Avatar-RedR32
Post08-03-2011, 0:05    Subject: Leon door lock Quote
Sure, no problem, I'll do it again.
reflexsilber met.
RedR32
Avatar-RedR32
Post08-03-2011, 18:28    Subject: Leon door lock Quote
The interior monitoring and alarm system is working again; it can be deactivated or activated via the driver's door lock cylinder. I read about this in the channel adaptation section and in the owner's manual icon_idea.gif. However, the indicator light in the door panel remains off icon_question.gif.
reflexsilber met.
Post08-03-2011, 18:39    Subject: Leon door lock Quote
Check if it works using actuator diagnostics.
RedR32
Avatar-RedR32
Post08-03-2011, 23:01    Subject: Leon door lock Quote
TDI-GTI-4-Motion wrote:
Check if it works via actuator diagnosis.
No, that's not possible.
reflexsilber met.
Post08-03-2011, 23:30    Subject: Leon door lock Quote
It's either the LED, the cable, or the door control unit that's defective. Just build them and apply some voltage.
Measure beforehand to see if and what arrives. Honestly, I'm not sure right now whether 12V is coming out of the control unit or just 1.8V.
RedR32
Avatar-RedR32
Post09-03-2011, 9:10    Subject: Leon door lock Quote
The VCDS software includes a diagnostic function for the indicator light, which can be helpful in identifying the problem. This means the fault is likely located either on the wiring between the control unit (TSG) and the light, or within the light itself. The SSP 193 document can also be useful. However, I can't determine the voltage at which the light is operating from this information. Tomorrow, we'll start by working on the clutch, and then we'll remove the door panel.
reflexsilber met.
RedR32
Avatar-RedR32
Post22-03-2011, 19:56    Subject: Leon door lock Quote
17€ for such a small diode with a piece of plastic, that's quite expensive.
reflexsilber met.
Post22-03-2011, 20:07    Subject: Leon door lock Quote
Was were you referring to?
RedR32
Avatar-RedR32
Post22-03-2011, 22:23    Subject: Leon door lock Quote
Were you on the line?
I don't know. Expansion.
It should arrive sometime this weekend or so.
reflexsilber met.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic door locking Transmission, Chassis, Body & Interior
No new posts Disable Automatic Door Lock: How-to Guide On-Board Diagnostics (OBD)
No new posts Polo 6R: Coming Home, Leaving Home, Door Lock Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vag-Com Codes for Seat Leon Diesel Engine Technology
