A3 Getriebe kaputt? 3.4.5. Gang gehen nicht. | Posts 16+
Go to page: Previous  1, 2
Karma: +1344 / -0   Thank you, like it!
Post13-09-2010, 2:24    Subject: Quote
I'm currently looking at the design of the CZL gearbox.
http://vagcat.com/epc/cat/au/A3/1997/201/51/2399058/,
http://vagcat.com/epc/cat/au/A3/1997/201/51/2399243/,
http://vagcat.com/epc/cat/au/A3/1997/201/51/2399827/,
What position does the side lobe occupy between the second and third?
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Translated on 22-09-2026, 9:16.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post13-09-2010, 10:15    Subject: Quote
The images, or whatever they are supposed to be, cannot be opened.
The sideband is the sideband.
The distance between the 2nd and 3rd gear stages on the countershaft is located between the 2nd and 3rd gear pairs.
Translated on 22-09-2026, 9:17.
Post13-09-2010, 20:09    Subject: Quote
I think we should postpone this discussion until you post the photos of the damage. Maybe we're just talking past each other.
If you are interested, the source of the images I linked is http://www.vagcat.com/.
"vg"
Tagessuppe
Post24-05-2011, 14:55    Subject: Quote
Okay, here's the solution.
Mir hat es doch tatsächlich diese Welle zwischen 2. und 3. Gang torn apart.
The last picture shows it best.
The designed weak point likely prevented more serious damage.
It's funny that it broke during the gear change, not while engaging the clutch.
I have to admit that I didn't take good care of the transmission, and it was certainly subjected to higher loads due to the chip and the sports clutch.
If someone needs spare parts for the CZL gearbox, just let us know icon_wink.gif.
 A3 3/97 GKB:CZL Getriebeschaden
 File size:  1.15 MB
 Viewed:  2278 times
 File size:  1.43 MB
 Viewed:  3692 times
 File size:  1.04 MB
 Viewed:  2006 times
 File size:  818.36 KB
 Viewed:  1898 times
Translated on 22-09-2026, 9:18.
findus170
Tagessuppe likes this.
Post24-05-2011, 20:41    Subject: Quote
I took a look at the fatigue crack script, and your damage appears to be caused by crack growth at a low nominal stress and a mild notch, likely due to circumferential bending.
The rough surface was the remaining cross-section that was torn off last; the crack started on the edge, opposite to it.
VG
Findus170
VW ID 7 GTX
Translated on 22-09-2026, 9:20.
Tagessuppe
Post24-05-2011, 22:45    Subject: Quote
Okay!
This shell-like growth at the fracture point also led me to this conclusion.
So, it seems this phenomenon is well-known?
Would you still say that the chip tuning and the sports clutch, along with my driving style, were to blame?
Or would that have happened regardless?
Translated on 22-09-2026, 9:21.
Post24-05-2011, 22:49    Subject: Quote
Tagessuppe wrote:
Would you still believe that the chip and the sports clutch, along with my driving style, were to blame,
Post25-05-2011, 8:25    Subject: Quote
How many kilometers were on the transmission?
Translated on 22-09-2026, 9:22.
Post25-05-2011, 8:39    Subject: Quote
So, this is the drive shaft? It's remarkable that, despite the one-sided bearing and the breakage, some of the gears were still usable.
findus170
Post25-05-2011, 9:19    Subject: Quote
Tagessuppe wrote:
Correct!
or would that have happened anyway?
Well, I would say that a surfboard made of flawless material probably wouldn't have broken.
However, I am not aware of any other cases of damage to this gearbox.
This is a fracture failure caused by stress, and there must be a starting point for crack growth. In my experience, the notch alone is usually not enough; there needs to be another factor involved. You should carefully examine the shaft, especially the edge opposite the remaining fractured section, to see if there's any irregularity in the grain structure or any signs of a pre-existing crack.
best regards
Findus170
VW ID 7 GTX
Translated on 22-09-2026, 9:23.
Tagessuppe
Post25-05-2011, 9:56    Subject: Quote
The transmission had 320,000 km on it, of which I drove 230,000 km with a performance chip and 150,000 km with a Sachs performance clutch.
My driving style is usually very relaxed and focuses on using torque, which the long 5th gear (0.68 instead of 0.717) further enhanced.
The old Luk clutch started slipping relatively quickly and likely only transmitted around 300-350 Nm of torque (depending on the temperature).
The clutch has such a strong grip that it hasn't even shown the slightest sign of slipping, even when engaging quickly in higher gears.
I would estimate it to be around 500-600 Nm.
Or could the much stiffer torsion suspension of the driving disc have played a role?
It doesn't matter. I think that's not so bad icon_wink.gif at 320,000 km.
The used gearbox with 80,000 km on it cost me 170,-, which is exactly what the long 5th gear would have cost.
Nowadays, I only needed 6 hours to replace the gearbox.
Translated on 22-09-2026, 9:26.
Post25-05-2011, 12:29    Subject: Quote
Translated on 22-09-2026, 9:27.
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Failure: Common Causes in Tuned Engines Diesel Engine Technology
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
