POLO 9N Catalytic Converter System - Insufficient Effectiveness
chriskross
Post14-01-2011, 15:50    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Hi!
I'm having another big problem with a POLO 1.2L AZQ, 3-cylinder gasoline engine.
The catalytic converter system's effect is too low. This error occurs approximately every 100 kilometers, and then the engine malfunction light remains on continuously.
Can the catalytic converter efficiency be read out using a VCDS diagnostic tool? And what lambda values should be considered?
Best regards.
Chris.
A6 AFB
A6 BRE DPF
Post14-01-2011, 21:07    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Possible causes of this error:
- Leak in the intake manifold or exhaust system.
- KAT faulty.
- Faulty oxygen sensor or its wiring.
Sure, here's the translation:
"Could you please post a VCDS Autoscan?" It would also be interesting to see the adaptation values of the Lambda tuning, as indicated in the label file.
chriskross
Post14-01-2011, 21:35    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Hello Rainer!
Here's the Autoscan. Can you tell me which MWB I should post?
"Thank you."
Best regards, Chris.
Vehicle type: 9N - VW Polo.
Scan: 01 02 03 08 09 15 17 19 37 44 45 46 56 76
Vehicle Identification Number: WVWZZZ9NZ2D015XXX
Mileage: 107,340 km
The quick brown fox jumps over the lazy dog.
Address 01: Engine Label file: RKS\03E-906-033-AZQ.lbl
Part number: 03E 906 033.
Component: 1.2L/4V SIMOS3 00HS4340
Encoding: 00071
Operating number: WSC 31414
VCID: DDB5498D7D43
WVWZZZ9NZ2D01XXXX VWZ7Z0A4516555
No errors found.
Readiness: 0000 0101
Address 03: Brakes. Label file: RKS\6Q0-907-37x-ABS2.lbl.
Part number: 6Q0 907 379 E
Part: ABS FRONT MK60 0103
Encoding: 0001097
Operating number: WSC 31414 000 00000
VCID: 3F891305170F
No errors found.
Address 08: Climate Control/Heating
Label file: RKS\6Q0-820-045.lbl
Part number: 6Q0 820 045.
Component: Air conditioner X0840.
VCID: EADF1251BC0D
2 errors found:
00819 - High-pressure sensor (G65)
07-00 - Signal too low.
01317 - Control unit in the instrument panel carrier (J285)
79-00 - Please read the error memory.
Address 09: Body Control Module. Label file: RKS\6Qx-937-049-B.lbl.
Part number: 6Q1 937 049 B
Component: ON-BOARD NETWORK - SG. 1S31
Encoding: 17566
VCID: 3A7F62110C2D
No errors found.
Address 15: Airbag Label File: RKS\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 S
Part number: 0A AIRBAG VW5 03 0006.
Encoding: 12353
VCID: 47990BE54FDF
No errors found.
Address 17: Combination instrument
Label file: RKS\6Q0-920-xxx-17.lbl
Part number: 6Q0 920 800 P
Part: COMBINATION INSTRUMENT + SPEEDOMETER VDO V11.
Encoding: 01131
Operating number: WSC 00000
VCID: 3A7F62110C2D
No errors found.
Address 19: CAN-Gateway Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 1S31.
Encoding: 00014
VCID: F0EB00399AD1
No errors found.
Address 44: Steering Assist
Label file: RKS\6Q0-423-156.lbl
Part number: 6Q0 423 156 AA
Component: Steering assist KYO X757.
Encoding: 10140
VCID: 6ED79E4100E5
Address 46: Comfort System
Label file: RKS\6Q0-959-433.lbl
Part number: 6Q0 959 433 H
Component: 1G Comfort Device 0001
Encoding: 00067
VCID: 408B10F96AF1
Part number: 6Q2959802A
Component: 1G Control Unit.FS TFK 0003
Part number: 6Q2959801A
Component: 1G Control Unit.BF TFK 0003
No errors found.
Ende
End.
A6 AFB
A6 BRE DPF
chli1976
Post14-01-2011, 22:13    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
I've experienced this same issue with a Polo before.
Traded my cat today, let's see if it works.
VCDS
Post14-01-2011, 22:22    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Even a lot of short-distance driving can cause this problem!
What driving conditions is the vehicle exposed to?
Post14-01-2011, 22:29    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Take a look at MWB 30 and the following entries in the label file of the engine control unit.
chriskross
Post15-01-2011, 12:50    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
I've created some logs here.
Best, Chris.
LOG-01-031-030-046.CSV
 File name:  LOG-01-031-030-046.CSV
 File size:  28.18 KB
 Downloaded:  1342 times
A6 AFB
A6 BRE DPF
chriskross
Post16-01-2011, 13:11    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
chli1976 wrote:
I also experienced this error with a Polo.
Today, I swapped the cat, let's see if it works.
Hi!
Has the error reappeared for you?
Could you possibly upload a few more so I have something to compare them to?
A6 AFB
A6 BRE DPF
chli1976
Post16-01-2011, 14:39    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
It was only two days ago.
So far, the error has not appeared, but it is probably too early to say anything definitive.
This is a log before I changed the cat, and I didn't create any logs after that.
LOG-01-001-033-036.csv
 File name:  LOG-01-001-033-036.csv
 File size:  56.6 KB
 Downloaded:  943 times
VCDS
Ross-Tech-Support
Post25-01-2011, 19:23    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Component: 1.2l/4V SIMOS3 00HS4340
Update the software; the current version should be at least 03E-906-033 @ 7000 (see TPI 2001227). Before that is done, the error detection can be icon_wink.gif essentially thrown away...
chriskross
Post30-06-2011, 16:44    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
Hello!
Unfortunately, I'm still experiencing this error even after the software update.
The error occurs approximately every 100 kilometers.
"At VW, they said that their diagnostic program only reported this error."
The KAT was renewed, but then the KAT and the entire system underwent a functional test to reset all readiness values, and all tests were successfully passed.
I'm not sure what to think or feel about it anymore.
A6 AFB
A6 BRE DPF
chli1976
Post30-06-2011, 19:23    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
What I did should have worked, but I haven't heard back from them.
VCDS
chriskross
Post30-06-2011, 19:54    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
I'll check the valve timing tomorrow, and then I'll probably have to replace the catalytic converter.
There will probably only be the original versions again; it's supposed to have three different versions.
A6 AFB
A6 BRE DPF
chriskross
Post04-07-2011, 11:19    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
The valve timings are also okay. I've cleaned the throttle body again; it was very dirty.
Here are the logs from the Lambda probes again. Perhaps someone can tell me what they mean.
LOG-01-014-313-332-361-991.rar
 File name:  LOG-01-014-313-332-361-991.rar
 File size:  9.66 KB
 Downloaded:  825 times
A6 AFB
A6 BRE DPF
Post04-07-2011, 11:30    Subject: POLO 9N Catalytic Converter System - Insufficient Effectiveness Quote
I've moved the topic. In the meantime, we have icon_wink.gif a more suitable subforum.
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0401 Error: Low EGR Flow - Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Catalytic Converter Error Code 16804: Low Efficiency On-Board Diagnostics (OBD)
No new posts LLC Effects: Some Mysteries Unveiled? Diesel Engine Technology
No new posts Recreation of the automatic brake system failure due to u... Transmission, Chassis, Body & Interior
No new posts SDI Polo: Specs, Price, and Review Diesel Engine Technology
