Passat 3B lock between 3rd and 5th gear. Gang no longer available.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
karlstein12
Post04-07-2011, 22:14    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
"In my Passat 3B, manufactured in March 2000 and equipped with a 5-speed transmission, the resistance that separates the shifting levels between gears 3/4 and gear 5 is no longer present."
"That is, when shifting into 3rd gear..." Sometimes you hear the third harmonic, but sometimes the fifth, and occasionally something in between, which produces an unpleasant sound.
I've removed the gear lever cover before, but I didn't get any further than that.
Before I take everything apart, can someone tell me where this resistance is coming from - at the shift linkage or at the transmission?
Does anyone know this problem, or its solution?
MKB: ATJ
GKB: EYZ
Sure, no problem. Here's the translation:
"Thank you in advance."
Greetings.
Rupert.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post04-07-2011, 22:43    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
Do the drawers slide in and out easily without scratching? Check the shift actuator; the shift rod that goes into the transmission may be defective - requires a workshop visit.
reflexsilber met.
voodoo
Post04-07-2011, 22:47    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
The 3B Bj3/2000 still uses the old linkage system.
It might be worth considering stopping it.
However, the shift linkage is generally always a bit more clunky than the later cable-operated systems.
karlstein12
Post05-07-2011, 13:45    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
The mechanism isn't actually complicated, and the gears fit in perfectly. I've also already checked the gear shift linkage; it's easily accessible from above.
Normally, the gear lever is in neutral in the 3/4 position. To shift into first or second gear, you push the lever to the left. To shift into fifth gear, you need to overcome the resistance by pushing the lever to the right. For some time now, the gear stick in my car has been getting stuck in a position somewhere between left and right, with no resistance.
It would be helpful to know how the gear lever is held in the 3/4 position when in neutral (e.g., by a spring). Possibly, I can then narrow down the source of the error and, consequently, the amount of work required for disassembly.
Rupert.
RedR32
Avatar-RedR32
Post05-07-2011, 18:58    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
karlstein12 wrote:
How the gear lever is held in the 3/4 position when in neutral (e.g., by a spring).
Rupert
Hi, there are locking screws installed in the transmission. These are screws with a small, spring-loaded ball that locks into the recesses on the shafts. This is all part of the shifting mechanism. These locking screws are usually replaceable from the outside.
I would check these locking screws first.
reflexsilber met.
karlstein12
Post06-07-2011, 21:59    Subject: Passat 3B lock between 3rd and 5th gear. Gang no longer available. Quote
Hello RedR32,
That was the right tip!
I found two locking screws on the camshaft. Out of those, one actually had no tension left on the spring/ball.
I'll order those tomorrow, then it should fit again.
Thank you and best regards.
Rupert.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Passat 3C - No keys available On-Board Diagnostics (OBD)
No new posts Passat AFN: CAN-Bus on MSG - Yes or No? On-Board Diagnostics (OBD)
No new posts Mercedes-Benz S124 200Td: More power and at least a 30% l... Diesel Engine Technology
No new posts New Beetle TDI: 5. The gang can't go out anymore Transmission, Chassis, Body & Interior
