Small Battery Box for ASZ - Save Space!
reuselkopp
Post15-06-2011, 19:26    Subject: Small Battery Box for ASZ - Save Space! Quote
Hello everyone,
I'm having a problem with my battery tray and cover. Since I replaced the standard air intake system in my Golf 4 Variant with the one from the R32 DSG, the battery tray only fits very tightly, and the cover doesn't fit at all. Because the battery I have installed, which is 70AH/340A, still has quite a bit of space on the sides, I would like to install a smaller battery tray and cover.
Installed is: 1J0 915 333 battery holder, 70AH/340A, 80AH/380A.
1J0 915 335 B Battery cover.
Would a battery terminal with the code 1J0 915 333 A, designed for a 44AH/220A battery and compatible with a 60AH/280A battery, fit my battery, along with the corresponding cover?
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 29-10-2026, 16:53.
Post15-06-2011, 21:36    Subject: Small Battery Box for ASZ - Save Space! Quote
Did you install everything correctly? I have the same unit and also converted it to the larger intake, but everything fits perfectly for me, just like before. icon_wink.gif
Translated on 29-10-2026, 16:54.
reuselkopp
Post16-06-2011, 6:47    Subject: Small Battery Box for ASZ - Save Space! Quote
Hello.
"I think I've put everything back together correctly this time. It's not particularly difficult. The expansion rivets fit, which means the position of the pipe attachment is correct, and the pipe itself is fastened to the inside of the fender. That also seems right. Perhaps the screw for the pipe is a bit further out on your G4 model. My G4 is model 05, one of the later ones, so maybe something was changed. I was even considering moving the attachment point where the pipe is screwed to the fender, but I'm not sure if the adhesive would hold."
Greetings.
Reuselkopp.
Translated on 29-10-2026, 16:55.
reuselkopp
Post17-06-2011, 7:16    Subject: Small Battery Box for ASZ - Save Space! Quote
Hello everyone,
"Does anyone have access to the AKTE database to check the dimensions of the console with part number 1J0 915 333 A, which is the 44AH/220A battery console, 60AH/280A, and its corresponding cover?"
Thank you and best regards.
Reuselkopp.
Translated on 29-10-2026, 16:56.
reuselkopp
Post19-06-2011, 13:35    Subject: Small Battery Box for ASZ - Save Space! Quote
Hello, I'm feeling desperate.
Does anyone have some dimensions for me? Is this information available in the VW program documentation (AKTE)?
Greetings.
Reuselkopp.
Translated on 29-10-2026, 16:57.
Post30-06-2011, 14:22    Subject: Small Battery Box for ASZ - Save Space! Quote
The dimensions are usually NOT included.
Sorry.
Octavia_4x4
Post06-07-2011, 13:26    Subject: Small Battery Box for ASZ - Save Space! Quote
Big intake? icon_razz.gif GTI, give me some info, could this work for me too? icon_smile.gif Mine is so slow. icon_biggrin.gif
Translated on 29-10-2026, 16:58.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post22-07-2011, 23:39    Subject: Small Battery Box for ASZ - Save Space! Quote
The pre-facelift Audi A3 has a battery holder that is quite narrow, allowing the battery to be easily shifted to the left or right.
Maybe this will help?
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Repair: Vibration Problems - Find a Mechanic Diesel Engine Technology
No new posts @ Tim 27 regarding pump tuning Diesel Engine Technology
No new posts @Thomas regarding Lupo Diesel Engine Technology
No new posts OBD Experts: Speedometer Issues & Solutions On-Board Diagnostics (OBD)
