DPF von Asche befreien statt tauschen | Posts 32+
Go to page: Previous  1, 2, 3
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Post20-11-2009, 16:36    Subject: Quote
gibt es in der praxis ĂŒberhaupt schon DPFs welche wegen des ascheeintrags getauscht werden mussten? im regelbetrieb wohlbemerkt? bei wie viel KM im schnitt?
According to the service booklet of my Audi, it has 120,000 km on the clock. However, based on the amount of ash present, it seems likely that it will need servicing at around 180,000 km.
I'll probably clean it beforehand, though, because the increased back pressure in the exhaust system only wastes power and fuel.
Translated on 12-07-2026, 3:07.
Karma: +1099 / -0   Thank you, like it!
Post20-11-2009, 18:58    Subject: Quote
Vermutlich reinige ich ihn aber vorher, da der erhöhte Abgasgegendruck nur sinnlos Leistung und Sprit kostet.
"...and as the load increases, it is also subjected to greater stress. This increased stress should also result in more wear and tear."
Translated on 12-07-2026, 3:08.
EMSimASZ
Post20-11-2009, 20:01    Subject: Quote
...groan... snore... snore... snore...
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post20-11-2009, 20:08    Subject: Quote
EMSimASZ wrote:
...gÀÀÀhhn.....schnarch.....schnarch....schnarch.....
@EMS
Since you have repeatedly criticized people here – and I mean really criticized them – don't be surprised when you receive a similar response in return.
And now please save your aforementioned witty nonsense, put your skirt back on, and stay productive on the topic, before it (rarely) makes my karma itch!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 12-07-2026, 3:09.
EMSimASZ
Post20-11-2009, 20:16    Subject: Quote
@DieselBÀÀÀr
Don't force yourself to do anything. That doesn't impress me at all.
It's not that I just talk nonsense; I've also written some very useful contributions. But only when I'm feeling particularly good.
Besides, I wanted to set a record: 'the person with the most points.'
And now let's stop with all the bickering...
Translated on 12-07-2026, 3:10.
Post20-11-2009, 20:55    Subject: Quote
EMSimASZ wrote:
Furthermore, I wanted to set a record: "the person with the most points"
If I could, I would very much like to help. icon_biggrin.gif You already have great views and opinions. Let me tell you something: based on what I've read about you so far, I still had some respect for you until two days ago. But what's coming out now is just a complete disaster. You really shouldn't be proud of accumulating negative karma points. icon_evil.gif
Translated on 12-07-2026, 3:11.
EMSimASZ
Post20-11-2009, 21:13    Subject: Quote
'I'm not proud of it, I just find it funny. I think it's embarrassing that a forum even offers something like that. Karma points??? Seriously??? Are we in kindergarten??? I personally find things like that 'totally ridiculous.' Honestly, I don't really care what people here think of me. I'm mostly just a silent observer anyway.'
Whenever I encounter topics like these, I always remember a time when I needed help some time ago... all I got were dismissive remarks and suggestions to 'use the search function.'
It doesn't really matter now anyway, I don't want to complain. Besides, there are other options besides the DS...
Translated on 12-07-2026, 3:13.
DieselBĂ€r30x
Post20-11-2009, 21:18    Subject: Quote
EMSimASZ wrote:
...und jetzt hör ma mal wieder auf mit der zickerei......
Are we done with the "out of topic" issue then?
Benni
Post20-11-2009, 22:23    Subject: Quote
Rainer K. wrote:
According to the service booklet for my Audi, it shows 120,000 km. However, based on the amount of ash buildup, it seems like it should be due for servicing at approximately 180,000 km.
Oh? I thought the additive-free DPFs were declared maintenance-free by Volkswagen.
Okay, then a lot of people will be really upset soon when these things have to be exchanged for almost nothing (what a pun).
Passat Variant Highline 3BG EZ 2/04 2,0 TDI mit DPF 235tkm 2x DPF gespĂŒlt - RIP dank LKW
Translated on 12-07-2026, 3:14.
Buddy
Post20-11-2009, 22:26    Subject: Quote
So far as I understand it, instead of waiting until the end, I should occasionally gently clean the DPF to reduce wear and tear on the catalytic converter within the DPF.
GrĂŒĂŸe Buddy
Golf3 Variant TDI Bj95 90PS und 203000km ohne Reparaturen
s202 C220 CDI T Bj98 125PS 133000 mit vielen Reparaturen
Translated on 12-07-2026, 3:15.
voodoo
Post04-07-2011, 21:48    Subject: Quote
Since my 2.0 TDI engine now has 58 grams of ash content after 180,000 km (the maximum is 60 grams), I will be having the cleaning process done soon.
I have already obtained the gaskets and seals. I will also replace the differential pressure sensor, including its lines, at the same time.
Since I don't have a garden hose available for my lift platform, I will probably need to use a paid car wash with a pressure washer. Furthermore, the oil separator there provides peace of mind icon_biggrin.gif.
Does anyone have any concerns about using the pressure washer?
Of course, one should use their judgment and not stare at a spot for minutes on end.
But in principle, the pressure washer should actually be more effective than a garden hose!
Translated on 12-07-2026, 3:16.
Post04-07-2011, 22:01    Subject: Quote
normalerweise sollte die Filterkeramik einen Hochdruckreiniger aushalten, ich wĂŒrde es aber nicht drauf ankommen lassen. Kannst uns ja berichten was passiert ist. icon_wink.gif
Furthermore, the water flow rate will likely be more important for success (a disadvantage of HDR compared to a garden hose), but you'll probably notice that yourself.
Otherwise:
It would be helpful to have the logs showing the differential pressure readings before and after, as described.
Translated on 12-07-2026, 3:18.
voodoo
Post04-07-2011, 22:16    Subject: Quote
Okay, that makes sense.
The high-pressure cleaner has a low mass flow rate because it produces a large volume of air and only a small amount of water at a high flow velocity.
The garden hose has a lower flow rate, but due to the large diameter of the nozzle, it has a comparatively higher mass flow rate.
So, then maybe I'll just do it with a garden hose instead. icon_rolleyes.gif icon_wink.gif
'@Rainer: By the way, your BRE engine seems very similar to my BPW.'
The filter on your pictures also has an 8E TN. The seals are the same as well.
You're driving a B8, right?
P.S. Unfortunately, I can't provide any logs. At most, I could stop by Dieselmartin's place beforehand.
Translated on 12-07-2026, 3:20.
voodoo
Post05-08-2011, 12:58    Subject: Quote
As I have also read in the forum, I have now flushed the filter.
However, I must say that you won't get much out of using a garden hose for this.
I've rinsed several times with the garden hose, but not much ash came out.
Initially, when using an industrial high-pressure cleaner with a rotating nozzle, large amounts of black debris came out of the filter.
The DPF ceramic material has survived perfectly well. No damage is visible.
Translated on 12-07-2026, 3:21.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts BMP, 180 Tkm, 58 g ash, and now? Diesel Engine Technology
No new posts Asche und Russ bei DPF-Regeneration Diesel Engine Technology
No new posts 195/60 statt 195/65 Transmission, Chassis, Body & Interior
No new posts Motortausch: TDI statt 1.8 ADZ Diesel Engine Technology
