Avenga Guest
06-08-2011, 20:08 Subject: VCDS: Beginner Questions & Answers |
Today, the package finally arrived from Switzerland.
I have the current 2.0 TDI CR engine with 125 kW (CEGA) in my 2011 Octavia RS.
I couldn't find the following in the measurement data blocks:
- Swirl flap angle/setting.
- Coolant temperature sensor 2 (use multiple if needed)
- AGR bypass valve switching position.
It appears there are 3 exhaust temperature sensors.
Before the turbo, before the catalytic converter, before the DPF.
I was surprised that the exhaust temperature before the turbo reached 500°C when starting in the city.
I used to think that a diesel engine only gets hot under full load.
It still stutters during the warm-up.
Translated on 14-10-2026, 8:58.
Avenga Guest
11-08-2011, 19:35 Subject: VCDS: Beginner Questions & Answers |
What's going on here? Nothing at all, or what?
I'm disappointed.
If anyone happens to stumble upon this and decides to answer, please do.
I found a temperature sensor in the engine control unit (ECU) that has no label - perhaps it's the coolant sensor?
Im erweiterten Messwertblock taucht die nicht auf, nur im Std. I'm sorry, I don't understand.
I've also noticed that some of the information in the extended coding assistant doesn't quite match, for example, 'Air quality sensor installed' = 0, even though I have one.
Or country code: 'Rest of the World' instead of 'Germany'.
'Is VCDS a 50/50 translation, or how should I understand it?'
Translated on 14-10-2026, 9:00.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
11-08-2011, 20:15 Subject: VCDS: Beginner Questions & Answers |
How about providing a VAG part number or running an Autoscan, or should we just guess?
Furthermore, I must defend Mr. Stange, who is responsible for the German/English labels.
I find it rather presumptuous to make such superficial remarks about the adequacy of a description for a control unit, especially considering the year of manufacture is 2011, and not even to specify which control unit is being referred to!
The ball is still in your court, but your tone is completely wrong; you should reconsider that.
Translated on 14-10-2026, 9:01.
Profile PM WWW Garage |
Avenga Guest
14-08-2011, 12:51 Subject: VCDS: Beginner Questions & Answers |
I didn't intend to offend you or Mr. Stange, that was not my intention.
But try to put yourself in my shoes.
Following multiple requests in this forum, I was repeatedly assured how great VCDS is.
Then I'll spend 300⏠and get a construction project and no answers to simple questions (is the exhaust temperature reasonable?).
Wouldn't you be disappointed?
I meant that I'm not looking for English-German translations, but rather the byte/bit representation of the text or measurement values. For example, the coolant temperature or intake manifold temperature appears multiple times within the extended measurement data.
Perhaps I expected too much, or maybe my model is too exotic or too new, or something like that.
I certainly don't want to offend anyone here.
I will provide the VAG part numbers or the results of the car scan later.
Translated on 14-10-2026, 9:03.
mullemaus Guest
14-08-2011, 13:25 Subject: VCDS: Beginner Questions & Answers |
For example, the coolant temperature or intake manifold temperature is included many times in the extended measurement data.
That's because of what the control unit outputs. If it happens 10 times, it will also appear 10 times in the memory word by word data  .
but rather the bytes/bits to the texts or measurements.
There are several factors to consider. Not EVERYTHING has been researched for every car. Specifically, not all control units have all of their bits/bytes known. Therefore, not all labels are always 1:1 accurate.
Translated on 14-10-2026, 9:05.
14-08-2011, 17:19 Subject: VCDS: Beginner Questions & Answers |
Quote: | | and get a construction site |
It's inherent to the nature of things that descriptions for new control units must be painstakingly created, rather than simply appearing out of nowhere. It's not okay to generalize this to the entire system.
Quote: | | and no answers to simple questions (exhaust temperature seems reasonable). |
I'm sorry that the 500°C is surprising you. If you reach into a socket, please don't be surprised, as there are 230V present.
Quote: | | I was surprised that the exhaust temperature before the turbo reached 500°C when starting in the city. |
If you write that it surprises you, that is not a question, but a statement.  In the German language, questions typically end with a question mark.
Translated on 14-10-2026, 9:07.
Avenga Guest
15-08-2011, 14:08 Subject: VCDS: Beginner Questions & Answers |
Here is the car scan.
Monday, August 15, 2011, 3:05:32:57989
VCDS Version: RKS 10.6.4
Data as of: 20110418.
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein.'
Vehicle type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
77
Vehicle Identification Number: TMBUH61Z***
01-Motor -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: Error 0010.
55-Beam adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
77-Phone -- Status: OK 0000
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen.'
Address 01: Engine (CEG)
Label file: RKS\03L-906-022-CBA.clb
Part number SW: 03L 906 022 RE, HW: 03L 906 022 GA.
Component: R4 2.0L EDC G000AG 5752.
Revision: 13H14--- Serial number:
Encoding: 0000078
Operating number: WSC 73430 790 00066
VCID: 79D6B97A4949
No errors found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: RKS\02E-300-0xx.lbl
Part number SW: 02E 300 054 H, HW: 02E 927 770 AL.
Part number: GSG DSG AG6, 511 2601.
Revision: 05351113 Serial number: 00001104031792
Encoding: 0000020
VCID: 1B1A83F2A335
No errors found.
Address 03: Brakes (J104)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BE, HW: 1K0 907 379 BE.
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Encoding: 143B601C092700FD280F06EA90190042350800
VCID: 76CCB2467857
No errors found.
Address 08: Climate Control/Heating (J255)
Label file: 5K0-907-044.clb
Part number SW: 3T0 907 044 BE Hardware number: 3T0 907 044 BE
Component: Climatronic
Part number: H16 0402
Revision: 00006001
Encoding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_SK35.rod
VCID: 76CCB2467857
No errors found.
Address 09: Body Control (J519)
Label file: RKS\1K0-937-08x-09.clb
Part number SW: 1K0 937 087 J HW: 1K0 937 087 J
Part: BCM PQ35 H 103 0615
Revision: 00103 AE
Encoding: 40000AB8E05BF1C040080080510091E4437800AE726D8560808540040040
Operating number: WSC 60348 427 93031.
VCID: 38507C7E32C3
Part number: 1Z1 955 119 D
Part: Wiper 08041 26 0601
Encoding: 00D7B7
Part number: 1K0 955 559 AH
Component: RLS 140411 05 54 0403
Encoding: 0730ED
Part number: 5J0 951 172.
Component: DWA sensor 03 03 1109
Part number: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
No errors found.
Address 10: Parking Assist 2 (J446)
Label file: RKS\5J0-919-475.clb
Part number SW: 5J0 919 475 A, Hardware number: 5J0 919 475 A.
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial Number: 32901109400911
Encoding: 10810F
Operating number: WSC 13765 790 00066
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000.rod
VCID: 334A4B522BA5
No errors found.
Address 15: Airbag
Label file: RKS\1K0-909-605.lbl
Part number SW: 1K0 909 605 T, HW: 1K0 909 605 T.
Part: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial Number: 0038PD2PNLNE
Encoding: 0020790
Operating number: WSC 73430 790 00079
VCID: 3D5E6D6A1DE1
No errors found.
Address 16: Steering wheel (J527)
Label file: 5K0-953-569.clb
Part number SW: 5K0 953 521 AT
Part number HW: 5K0 953 569 B
Component: STEERING MODULE 014 0140
Revision: FF010040 Serial number: 20110412200714
Encoding: 189A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: Not applicable.
VCID: 7EDCAA665067
Part number SW: 3T0 959 537 A, Hardware: 3T0 959 537 A.
Component: E221__MFL-URO H07 0012
Encoding: 830000
No ASAM data available for the control unit: 'EV_SMLSNGVOLWSXS'.
No errors found.
Address 17: Combination Instrument (J285)
Label file: RKS\5K0-920-xxx-17.clb
Part number SW: 1Z0 920 843 N, HW: 1Z0 920 843 N.
Component: KOMBI H20 0420
Serial number: 00000000000000
Encoding: 110E01
Operating number: WSC 73430 031 00066
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 43AA1B927B05
No errors found.
Address 19: CAN-Gateway (J533)
Label file: 7N0-907-530-V2.clb
Part number SW: 7N0 907 530 C, HW: 1K0 907 951.
Component: J533 Gateway H37 0614.
Revision: H37 Serial Number: 130411F2001467
Encoding: 352302
VCID: 3040445EDAB3
No errors found.
Address 25: Immobilizer (J334)
Label file: 5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAF41636BCEF
No errors found.
Address 2E: Media Player 3 (J650)
Label file: RKS\5N0-035-342.lbl
Part number SW: 5N0 035 342 D. Part number HW: 5N0 035 342 D.
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial Number: 7669776117
Encoding: 010000
VCID: 2870AC3EE263
No errors found.
Address 42: Door electric, driver's side.
Label file: RKS\1K0-959-701-MAX3.lbl
Part number SW: 1T0 959 701 AA, Hardware: 1T0 959 701 AA.
Component: Door seal 009 2119
Coding: 0004342
VCID: 76CCB2467857
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K0 909 144 M
Component: EPS_ZFLS, Size 74 3201
Revision: 00H20000
VCID: 3448484E2EAB
No errors found.
Address 52: Door electronics, passenger side.
Label file: RKS\1K0-959-702-MAX3.lbl
Part number SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 48B00CBE4223
'One error found:'
00933 - Power window motor, passenger side (V148)
005 - No or incorrect initial setup/adjustment.
Address 55: Headlight range adjustment.
Label file: RKS\5M0-907-357-V2.lbl
Part number SW: 5M0 907 357 C. Hardware: 5M0 907 357 C.
Component: AFS Control Unit 0148
Revision: 00H04000 Serial Number:
Encoding: 1507354
VCID: 3448484E2EAB
Part number: 7L6 941 329 B
Component: AFS-Lst. Module l 0004
Encoding: 00000023
Component: AFS-Lst. module r 0004
Encoding: 00000023
No errors found.
Address 56: Radio (J503) Label file: RKS\5M0-035-1xx-56.clb
Part number SW: 1Z0 035 156 G, HW: 1Z0 035 156 G.
Component: BOLERO 015 0029
Revision: -----29S
Serial number: SKZ4Z3L1120851
Encoding: 090004000001
VCID: 364C724638D7
No errors found.
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN3.lbl
Part number SW: 5K0 959 703 A, HW: 5K0 959 703 A.
Component: Door seal 007 2101
Encoding: 0000144
Operating number: WSC 73430 790 1012546
VCID: 32444E56D4BF
No errors found.
Address 72: Door electric strike, high, right.
Label file: RKS\1K0-959-704-GEN3.lbl
Part number SW: 5K0 959 704 A, HW: 5K0 959 704 A.
Encoding: 0000144
VCID: 334A4B522BA5
No errors found.
Address 77: Phone (J412)
Label file: RKS\7P6-035-730.clb
Part number SW: 5K0 035 730, HW: 5K0 035 730.
Component: TELEPHONE H09 1020
Revision: 1B001001 Serial Number: 00007669738001
Encoding: 0100000000010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA_SK35.rod
VCID: E2E47E1644DF
No errors found.
End.
Translated on 14-10-2026, 9:36.
15-08-2011, 21:19 Subject: VCDS: Beginner Questions & Answers |
- AGR bypass valve switching position |
If you go to the advanced measurement blocks, then search for...
- Intake manifold flap for airflow control.
- Exhaust gas recirculation cooling function.
If you found a temperature reading without a label in the "normal" measurement block, it definitely wasn't measurement block 7, 99, or 100, because everything in those blocks is labeled.
You could ask the developer at VAG what that is and then share your findings with us.
Details about the engine can be found in SSP 403, http://erwin.volkswagen.de
Translated on 14-10-2026, 10:05.
Avenga Guest
22-08-2011, 16:42 Subject: VCDS: Beginner Questions & Answers |
Hi there.
I just checked again, but I couldn't find a 'search for' option.
Where can I find the developer?
I already have the SSP.
Translated on 14-10-2026, 10:07.
22-08-2011, 18:41 Subject: VCDS: Beginner Questions & Answers |
Avenga wrote: | Hi.
I just checked again, but I couldn't find a "search for" option.
I already have the SSP. |
In an alphabetically sorted list, it's usually predictable where "A" will be and that "B" will follow. Consequently, it's also quite predictable where "K," like "coolant temperature," can be found.
To be honest, your posts show that you either have no interest in diagnosing or troubleshooting the car, or you are completely overwhelmed.
In both cases, I unfortunately have to admit that I cannot help you.
Instead, false claims are posted ("construction site" when every control unit has a label in the car scan), "questions" are not phrased as such, and you just engage in gossip.
Constructive criticism is welcome, but venting frustration is not.
Since I don't want my customers to be dissatisfied, I offer you the option to return the system for a full refund of the purchase price. Please contact me by email for details on the return process.
Translated on 14-10-2026, 10:09.
22-08-2011, 21:59 Subject: VCDS: Beginner Questions & Answers |
Avenga wrote: | | In any case, I don't want to offend anyone here. |
Sure, go ahead.
Avenga wrote: | ...Honestly, Rainer, I'm really at my wit's end.
Just like the dumb answer from "christians," which would have received a spam warning in other forums... |
Avenga wrote: | | I demand that you reactivate my account immediately and apologize. |
Unfortunately, the worst of your lies have already been deleted, but in the future, things like that will be archived because of people like you.
I will not tolerate the spread of falsehoods in this support forum, nor will I accept being subjected to such blatant and vulgar behavior. No other forum member or moderator should have to endure such insults from you.
People like you are not only unwelcome here. Instead of reacting to hateful lies and insults, we prefer to spend our time on constructive conversations with people who know how to behave properly.
Actions speak louder than words, and that's why this tragedy ends here.
Translated on 14-10-2026, 10:12.
