Fuel Temp Sensor Spoofing Possible in CR Engines?
hharry
Karma: +2 / -1   Thank you, like it!
Post12-08-2011, 16:30    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
"With the 'cheap' tuning boxes for PD TDI engines, the signal from the fuel temperature sensor is usually manipulated or replaced with a fixed resistance value (often 150 ohms, which corresponds to approximately 100°C? Please correct me if I'm wrong)."
I haven't seen this principle applied in CR engines before. Is there no expectation of a performance increase here?
Best regards.
Harald.
Translated on 14-09-2026, 22:44.
Post15-08-2011, 1:31    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
With CR engines, cheap control units can cause inaccurate rail pressure readings.
Translated on 14-09-2026, 22:45.
chli1976
Post15-08-2011, 8:41    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
I only know about it in terms of temperature, even with CR engines.
In the newer generations of CR engines, the rail pressure is calculated. The rail pressure sensor is now only used to periodically verify the calculated rail pressure.
VCDS
hharry
Post23-08-2011, 20:52    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
I've also seen those sensors that distort the rail pressure signal, but I haven't encountered a temperature sensor issue yet. Or, does the fuel not get as hot in common rail (CR) engines as it does in pump-injector (PD) engines?
Translated on 14-09-2026, 22:46.
vwSchrauber
Post24-08-2011, 16:14    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
In the newer generations of CR engines, the rail pressure is calculated. The rail pressure sensor is now only used to occasionally compare the calculated rail pressure with the actual value.
"New" in what sense?
chli1976
Post25-08-2011, 6:07    Subject: Fuel Temp Sensor Spoofing Possible in CR Engines? Quote
Believe from Common Rail Generation 4.
At least, that's what a VW trainer claimed.
VCDS
Translated on 14-09-2026, 22:47.
No new posts Golf III TD Lenkgetriebe ausgeleiert, zwei Hersteller m�... Transmission, Chassis, Body & Interior
