Differential Pressure Sensor Skoda Fabia 5J
Micha81
Registered VCDS User
Post26-08-2011, 13:01    Subject: Differential Pressure Sensor Skoda Fabia 5J Quote
Is it necessary to adjust the differential pressure sensor (DPF) after replacing it on a Skoda Fabia 5J 1.4 TDI manufactured in 2008? If so, how can this be done using VCDS (without a label file)? Thank you in advance for your help.
Log-L-EO8890-TMBGF65J193032405-56570km.txt.txt
 Log Fehlerspeicher
Log Fehlerspeicher
 File name:  Log-L-EO8890-TMBGF65J193032405-56570km.txt.txt
 File size:  4.26 KB
 Downloaded:  1136 times
Translated on 09-09-2026, 18:05.
Post26-08-2011, 16:12    Subject: Differential Pressure Sensor Skoda Fabia 5J Quote
Yes, it's possible with VCDS, see:
/viewtopic.php?t=23802&highlight=differential pressure sensor calibration
Translated on 09-09-2026, 18:06.
Micha81
Post26-08-2011, 20:06    Subject: Unfortunately, it doesn't work Quote
Me again, with the usual stuff:
VAG-COM/VCDS > Selection > 01 - Engine Control > Coding 2 - 11.
30605 = Adjustment of exhaust gas pressure sensor 1 (G450).
Unfortunately, it doesn't work here (the encoding is not accepted). icon_confused.gif
Micha
Translated on 09-09-2026, 18:07.
Post26-08-2011, 20:16    Subject: Differential Pressure Sensor Skoda Fabia 5J Quote
Conversely, what pressure difference and offset does your sensor display when the engine is off and the ignition is on?
Have you also tried "Security Access" instead of "Encoding II"?
Translated on 09-09-2026, 18:08.
Ross-Tech-Support
Post04-09-2011, 12:34    Subject: Differential Pressure Sensor Skoda Fabia 5J Quote
According to the latest data available, the following note applies to this engine:
If the automatic adjustment of the exhaust pressure sensor fails, you must perform it manually as follows. The following steps must be repeated 5 times!
1. Ignition ON.
Wait 2.5 seconds.
3. Ignition OFF.
4. Wait for 40 seconds.
Translated on 09-09-2026, 18:09.
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DK Skoda Fabia 1.4L 16V Gasoline Engine Technology
No new posts Skoda Fabia RS - Tuning Upload
No new posts Tie Rod Replacement Skoda Fabia Transmission, Chassis, Body & Interior
No new posts ABS Control Module Replacement Skoda Fabia 6Y On-Board Diagnostics (OBD)
