MStG 038 906 018 P def. nach PLCC-Sockel-Riß (GELÖST) | Posts 16+
Go to page: Previous  1, 2
DieselBär30x
Avatar-DieselBär30x
Post25-09-2011, 11:33    Subject: Quote
Hi Rainer!
GRA is now working again, and the status bits are being displayed correctly icon_wink.gif.
Best regards from Munich!
Translated on 23-08-2026, 11:40.
Post25-09-2011, 11:46    Subject: Quote
Hello Bear,
What remains is this annoying error message: "StG defective!".
It's possible that this message will disappear if you replace the EEPROM or repair its contents, but it's not guaranteed.
Unfortunately, it's not really clear why the control unit identifies itself as "faulty." There could be many other reasons for this.
My advice would be to leave everything as it is, as long as the "glow plug" indicator light in the cockpit isn't flashing and the car is running smoothly without any issues.
As a teenager, I once painted my Kreidler Florett in blue metallic paint. It looked great, but it could have had a little more sparkle. Because it didn't glitter enough in the sun, I kept experimenting with the paint and eventually messed up the entire paint job. -> Never change a good running system. icon_wink.gif
I hope you understand what I mean. To fix a "bug" that has no effect whatsoever, except when you ask the control unit how it's doing and it says "Well, I feel broken"... just stick a note on the bottom of the control unit that says "I feel good." That's less risky than taking it out, disassembling it, and messing around with its internals icon_wink.gif.
Translated on 23-08-2026, 11:42.
mullemaus
Post25-09-2011, 12:41    Subject: Quote
If the checksums fit in flash memory, only the EEPROM needs to be fixed. This can then icon_wink.gif.
Translated on 23-08-2026, 11:44.
DieselBär30x
Avatar-DieselBär30x
Post26-09-2011, 11:54    Subject: Quote
Hello everyone and thank you for your replies!
@Rainer: I understand that "never touch a running system" is a good rule to follow, and I generally agree with it. However, I always have this uneasy feeling that the EEPROM or the engine control unit (ECU) might suddenly fail, especially if even just one more bit gets corrupted...
According to Murphy's Law, this will happen at the most inopportune moment, of course. icon_rolleyes.gif
If possible, I would still like to replace the EEPROM. If the problem persists after that, I won't have any other choice but to hope for the best and possibly replace the entire engine control unit (or annoy Wiesel *g*).
@Mulle: Can you tell me what the equivalent type is for the Bosch part number B58253?
Thank you so much again, and sunny greetings from Munich!
Translated on 23-08-2026, 11:45.
Wiesel
Post26-09-2011, 20:51    Subject: Quote
24C02
If you need a dataset, just let me know.
Micha
Translated on 23-08-2026, 11:46.
DieselBär30x
Avatar-DieselBär30x
Post24-10-2011, 15:50    Subject: Quote
Hello everyone!
Wiesel wrote:
... If you need a dataset, just let me know. ...
Thanks to Wiesel, my VAT system is now running again without the "Error!" message in the error memory icon_thanks.gif.
The data stored in the I²C memory on the back of the main control unit (MStG) was corrupted. It has been replaced with a new version burned by Micha, and the vehicle identification number (AFN) is now working again as if nothing had happened icon_wink.gif.
Once again, many thanks to everyone for the help and especially to our (Diesel) Wiesel! icon_cool.gif
Translated on 23-08-2026, 11:48.
Wiesel
Post24-10-2011, 17:03    Subject: Quote
Thank you for your feedback!
It's great that it's working perfectly again.
Micha
Translated on 23-08-2026, 11:49.
Post24-10-2011, 18:22    Subject: Translating...
[Translating...]
DieselBär30x
Avatar-DieselBär30x
Post24-10-2011, 22:41    Subject: Quote
dieselschrauber wrote:
...and of course, many thanks again to Rainer for the PLCC flat rate icon_lol.gif.
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Short Circuit Error 004160: Solved! Diesel Engine Technology
No new posts No power after timing belt/chain replacement / Passat TDI... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Problems after timing belt replacement on 1.9 TDI BKC eng... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Synchronization angle 16V PD Germany (SOLVED) On-Board Diagnostics (OBD)
