Leistungsmangel A4 Avant 1,9TDI - 90PS AHU 1996 | Posts 16+
Go to page: Previous  1, 2
Post13-04-2012, 8:37    Subject: Quote
Herbert wrote:
The 1Z engine was also installed longitudinally in the Audi.
That's correct. The 1Z engine, like the AFN, was available in both longitudinal and transverse configurations. icon_wink.gif
Okay, I've changed it in the original post.
Translated on 14-10-2026, 6:15.
Post13-04-2012, 8:53    Subject: Quote
You don't need to check the VTG (variable turbine geometry) on an AHU engine because it has a wastegate turbocharger.
The boost pressure shown in the diagram is quite good for the amount of air mass.
If the obvious possibilities like a blocked air filter, obstructed intake path, or a faulty catalytic converter have been ruled out, I would start looking at the mass airflow sensor (MAF) or the exhaust gas recirculation (EGR) system.
Please record the measurements for MWB 3 in the LL (low-load) condition and under load, as well as the measurements for MWB 10 and 11 under load.
Close the AGR for testing purposes as well.
Translated on 14-10-2026, 6:16.
charmillo
2005 Audi A6 Avant
Post13-04-2012, 9:26    Subject: Quote
Hello Herbert,
Thank you for the tips... I'll take a closer look at it during the weekend. The catalytic converter should be fine, as the exhaust emissions passed the "Contrôle technique" (technical inspection) last week, so I think the catalytic converter is in good condition.
Hmmm, okay, here's a silly question, but how is the best way to disable the EGR valve on this engine...? Just by unplugging the connector? Or is there something else, like putting a piece of metal in it?
I will be conducting the measurement tests with him tomorrow.
Regards...
Translated on 14-10-2026, 6:18.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post13-04-2012, 9:54    Subject: Quote
It's best to use a mechanically locking mechanism because you never know for sure if it will automatically release on its own icon_wink.gif.
Post13-04-2012, 10:12    Subject: Quote
"Well, I guess your TÜV (German technical inspection agency) doesn't do much more than ours. The measurement will probably only focus on the opacity, and won't test the effectiveness of the catalytic converter... but whatever."
Tapping icon_wink.gif is faster than typing anything }, and you instantly become smarter.
Translated on 14-10-2026, 6:19.
Post13-04-2012, 21:05    Subject: Quote
For temporary sealing: Metal. Permanent sealing is not permitted due to exhaust emission regulations.
Schraube auch mal den Kat auf der Motorseite ab und schau rein. Ist noch besser wie Schütteln, da klarer Einblick, und betrifft drei Schrauben.
Translated on 14-10-2026, 6:21.
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 1.9 TDI: Error Code 00575 - Troubleshooting On-Board Diagnostics (OBD)
No new posts Audi A4 1.9 TDI: Error Code 00575 - Troubleshooting Guide Upload
No new posts Golf 3 TDI: Rear axle knocking noise Transmission, Chassis, Body & Interior
No new posts Audi 80 B4: High Front - Troubleshooting Guide Transmission, Chassis, Body & Interior
