Climatronic coding not changeable?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
matt
Post12-08-2013, 22:10    Subject: Climatronic coding not changeable? Quote
Hello everyone,
Is it normal that the coding of the Climatronic cannot be changed? The vehicle is a 2005 Passat 3BG.
The input from a different encoding simply isn't being saved. Does this require a login code?
Matthias.
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post12-08-2013, 22:22    Subject: Climatronic coding not changeable? Quote
Hi Matthias!
Please always perform a complete vehicle scan first and post the results here.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
matt
Post13-08-2013, 14:51    Subject: Climatronic coding not changeable? Quote
Hello DieselBĂ€r30x,
Thank you for your feedback! I have attached a scan of all the control units. I hope this helps.
Matthias.
Auto-Scan.pdf
 File name:  Auto-Scan.pdf
 File size:  4.65 KB
 Downloaded:  1837 times
Post13-08-2013, 17:31    Subject: Climatronic coding not changeable? Quote
The VAG-COM version used is no longer supported.
Please use VCDS-Lite.
matt
Post14-08-2013, 11:00    Subject: Climatronic coding not changeable? Quote
I completely forgot to mention that saving with a different encoding also fails with the current VCDS version.
The question of whether a login code is required still remains.
mullemaus
Post14-08-2013, 13:45    Subject: Climatronic coding not changeable? Quote
I completely forgot to mention that saving a different encoding also fails with the current VCDS version.
The question of whether a login code is required still exists.
Please do that once.
Then it continues. Not before icon_cool.gif.
matt
Post16-08-2013, 12:43    Subject: Climatronic coding not changeable? Quote
Hello everyone,
Attached is a scan using the current VCDS-Lite software.
The result, regardless of the version – whether it's the current VCDS license with the corresponding interface, VCDS-Lite, or the older VAG-COM – is always the same: I cannot change the coding of the Climatronic.
Matthias.
VCDS-Lite Auto-Scan Printout.pdf
 File name:  VCDS-Lite Auto-Scan Printout.pdf
 File size:  3.58 KB
 Downloaded:  800 times
Post16-08-2013, 16:15    Subject: Climatronic coding not changeable? Quote
The result is that I cannot change the coding of the Climatronic.
change to what?
matt
Post16-08-2013, 18:51    Subject: Climatronic coding not changeable? Quote
Hello Rainer,
Changing from 17000 to 17200. This is the US setting. This adjustment is intended to better cater to the preferences of customers in the United States, particularly regarding the Climatronic system. I would like to test this setting to see if it works better for me.
Matthias.
Post16-08-2013, 19:06    Subject: Climatronic coding not changeable? Quote
I can easily imagine that for us Europeans, the American coding system isn't appealing, because the Americans tend to exaggerate with their climate zones. icon_confused.gif
Post16-08-2013, 20:32    Subject: Climatronic coding not changeable? Quote
VW Passat without L-shaped flap (3BG - Model year 2000 >)
"Are you sure this air conditioning system was ever available with US-market coding for this vehicle?"
Find only "3B1 907 044 J" using "17200" as the encoding.
matt
Post16-08-2013, 20:51    Subject: Climatronic coding not changeable? Quote
Hello Rainer,
I cannot be entirely certain about that icon_sad.gif. My only source of information is the former openobd website. Of course, it's possible that the information provided isn't always 100% accurate.
Matthias.
matt
Post21-08-2013, 15:34    Subject: Climatronic coding not changeable? Quote
Sure, here's the translation:
'Quick question:'
So, is it actually normal for the used Climatronic control unit in this case that other codings are simply not accepted?
Matthias.
Post22-08-2013, 13:16    Subject: Climatronic coding not changeable? Quote
matt wrote:
Quick question:
Matthias
Others may have, but probably not the specific one you're looking for. As I mentioned before, I am not aware of any vehicle with the desired coding and that uses the parts with the part numbers and .
matt
Post22-08-2013, 22:26    Subject: Climatronic coding not changeable? Quote
Hi Rainer,
Then I guess that's just the way it is.
Thank you for your assistance.
Matthias.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Golf 4: Speedometer Coding - Not Changeable! On-Board Diagnostics (OBD)
No new posts Climatronic Coding: How to Program Your Car On-Board Diagnostics (OBD)
No new posts Adjustable Interior Temp. Setting (22°C) for Auxiliary H... On-Board Diagnostics (OBD)
No new posts I can't access the service mode of the Climatronic! Transmission, Chassis, Body & Interior
